Проверка fsck на CentOS
Установил exastix-овый centos. Сразу после установки при проверке fsck появляется такое: fsck 1.39 (29-May-2006) Warning! /dev/VolGroup00/LogVol00 is mounted. Warning: skipping journal recovery because doing a read-only filesystem check. /dev/VolGroup00/LogVol00 contains a file system with errors, check forced. Pass 1: Checking inodes, blocks, and sizes Deleted inode 16351237 has zero dtime. Fix? no Inodes that were part of a corrupted orphan linked list found. Fix? no Inode 16351238 was part of the orphaned inode list. IGNORED. Inode 16351239 was part of the orphaned inode list. IGNORED. Inode 16351240 was part of the orphaned inode list. IGNORED. Inode 16351241 was part of the orphaned inode list. IGNORED. Pass 2: Checking directory structure Entry 'db.backup1' in /var/lib/imap (16154633) has deleted/unused inode 16221232. Clear? no Pass 3: Checking directory connectivity Pass 4: Checking reference counts Pass 5: Checking group summary information Block bitmap differences: -16115300 -16119116 -16150528 -16248876 -16249016 -(16249086--16249088) -(16249269--16249271) -(16249303--16249305) -(16249516--16249518) -(16249525--16249528) -(16249537--16249542) -(16249544--16250879) -16250887 -(16251320--16252525) Fix? no Free blocks count wrong for group #491 (12343, counted=12216). Fix? no Free blocks count wrong (35452190, counted=35435825). Fix? no Inode bitmap differences: -(16221232--16221235) -(16351237--16351241) Fix? no Free inodes count wrong (37020713, counted=37019919). Fix? no /dev/VolGroup00/LogVol00: ********** WARNING: Filesystem still has errors ********** /dev/VolGroup00/LogVol00: 72663/37093376 files (0.3% non-contiguous), 1632994/37085184 blocks Перезагружаюсь с лайв cd fsck ничего не находит. После загрузки с основного диска находятся те же самые ошибки. Подскажите что я делаю не так? ... |
| 20.11.2014, 23:15:06 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1482286]: |
53ms |
47ms |
| others: | 334ms |
| total: | 515ms |
