bin/bash: error на centos
parallel -j0 ping -nc 3 ::: foss.org.my gnu.org freenetproject.org parallel: Warning: YOU ARE USING --tollef. IF THINGS ARE ACTING WEIRD USE --gnu. parallel: Warning: --tollef is obsolete and will be retired 20140222. parallel: Warning: See: http://lists.gnu.org/archive/html/parallel/2013-02/msg00018.html /bin/bash: -c: option requires an argument /bin/bash: 3: command not found /bin/bash: foss.org.my: command not found /bin/bash: :::: command not found /bin/bash: gnu.org: command not found /bin/bash: freenetproject.org: command not found Usage: ping [-LRUbdfnqrvVaA] [-c count] [-i interval] [-w deadline] [-p pattern] [-s packetsize] [-t ttl] [-I interface or address] [-M mtu discovery hint] [-S sndbuf] [ -T timestamp option ] [ -Q tos ] [hop1 ...] destination на ubuntu тотже самый код работает впринципе неплохо. parallel установлен через yum. систему обновил yum update ... |
| 14.02.2015, 01:10:24 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1482190]: |
30ms |
77ms |
71ms |
| others: | 393ms |
| total: | 648ms |
