FreeBSD Помогите обновить libarchive-3.2.2,1 до 3.3.2
Нужно установить самбу, в процессе установки и обновления пакетов вылезла ошибка в компиляции libarchive-3.3.2 Устанавливаю через portmaster FreeBSD backup.xxx.ru 10.1-RELEASE-p19 FreeBSD 10.1-RELEASE-p19 #0: Sat Aug 22 03:55:09 UTC 2015 root@amd64-builder.daemonology.net:/usr/obj/usr/src/sys/GENERIC amd64 --- libarchive_fe/libarchive_fe_la-err.lo --- libtool: compile: cc -DHAVE_CONFIG_H -I. -I./libarchive -I/usr/local/include -DLIBICONV_PLUG -O2 -pipe -I/usr/local/include -DLIBICONV_PLUG -fstack-protector -fno-strict-aliasing -Wall -Wformat -Wformat-security -MT libarchive_fe/libarchive_fe_la-err.lo -MD -MP -MF libarchive_fe/.deps/libarchive_fe_la-err.Tpo -c libarchive_fe/err.c -o libarchive_fe/libarchive_fe_la-err.o >/dev/null 2>&1 --- libarchive/archive_disk_acl_freebsd.lo --- 2 errors generated. *** [libarchive/archive_disk_acl_freebsd.lo] Error code 1 make[3]: stopped in /usr/ports/archivers/libarchive/work/libarchive-3.3.2 --- libarchive_fe/libarchive_fe_la-err.lo --- mv -f libarchive_fe/.deps/libarchive_fe_la-err.Tpo libarchive_fe/.deps/libarchive_fe_la-err.Plo 1 error make[3]: stopped in /usr/ports/archivers/libarchive/work/libarchive-3.3.2 *** [all] Error code 2 make[2]: stopped in /usr/ports/archivers/libarchive/work/libarchive-3.3.2 1 error make[2]: stopped in /usr/ports/archivers/libarchive/work/libarchive-3.3.2 ===> Compilation failed unexpectedly. Try to set MAKE_JOBS_UNSAFE=yes and rebuild before reporting the failure to the maintainer. *** Error code 1 Stop. make[1]: stopped in /usr/ports/archivers/libarchive *** Error code 1 Stop. make: stopped in /usr/ports/archivers/libarchive ===>>> make build failed for archivers/libarchive ===>>> Aborting update ===>>> You can restart from the point of failure with this command line: portmaster <flags> archivers/libarchive ... |
| 08.02.2018, 18:02:43 |
westvovikдо 3.3.2Вроде как, нынче актуальная libarchive-3.3.2,1 - без проблем собирается, правда, на актуальном 10.3-RELEASE. Или, годами не обновляемый 10.1-RELEASE уже не поддерживает обновление дерева портов? ... |
| 09.02.2018, 00:29:46 |
Начните с того, что сделайте в /usr/ports/archivers/libarchive make clean, а вообще, если срез портов свежий, то прав vkle, может не собраться из-за неподдерживаемой версии операционки, тогда иногда помогает опция ALLOW_UNSUPPORTED_SYSTEM=yes в /etc/make.conf, но я считаю, что проще и правильнее обновиться до актуальной 10.3 ... |
| 09.02.2018, 01:12:00 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1481396]: |
50ms |
67ms |
| others: | 318ms |
| total: | 510ms |
