Как в кроне сделать запуск каждую первую среду месяца?
Добрый день. Как в кроне сделать запуск каждую первую среду месяца? ... |
| 15.09.2020, 12:04:23 |
man crontabNote: The day of a command's execution can be specified by two fields — day of month, and day of week. If both fields are restricted (i.e., don't start with *), the command will be run when either field matches the current time. For example, "30 4 1,15 * 5" would cause a command to be run at 4:30 am on the 1st and 15th of each month, plus every Friday. One can, however, achieve the desired result by adding a test to the command (see the last example in EXAMPLE CRON FILE below).Ну и в EXAMPLE CRON FILE: Код: plaintext 1. 2. ... |
| 15.09.2020, 14:36:34 |
Barlone man crontabNote: The day of a command's execution can be specified by two fields — day of month, and day of week. If both fields are restricted (i.e., don't start with *), the command will be run when either field matches the current time. For example, "30 4 1,15 * 5" would cause a command to be run at 4:30 am on the 1st and 15th of each month, plus every Friday. One can, however, achieve the desired result by adding a test to the command (see the last example in EXAMPLE CRON FILE below). Код: plaintext 1. 2. Спасибо, то что надо! А я уже хотел вингдовым шедулером делать. ... |
| 16.09.2020, 14:34:58 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1480991]: |
26ms |
39ms |
78ms |
| others: | 354ms |
| total: | 561ms |
