Коннект с SQL 7.0 в PHP
Дайте скриптик на РНР для конекта с SQL 7.0 ... |
| 25.02.2003, 16:48:15 |
$pconnect = mssql_pconnect ("k13", "k12_iis" ) or die("unable to connect to msql server: ".msql_error()); $rs = mssql_query("select * from spr_baz") ; $nrows = mssql_num_rows ($rs) ; for ($i=1; $i<=$nrows; $i++) { $k = mssql_fetch_row($rs); $k9 = $k; echo ($k9) ; }; ... |
| 04.03.2003, 14:27:15 |
start [/forum/topic.php?fid=23&gotonew=1&tid=1480669]: |
212ms |
46ms |
| others: | 237ms |
| total: | 553ms |
