(Perl) Help
Guys, I am new in perl and I need your help! I have an error somebodyes code. PerlTray 6.0.0 build 117102 syntax error at CreatePackageRename.pl line 81, near ") ) " syntax error at CreatePackageRename.pl line 84, near "}" Code is below. it is doesn't like if. if ( $Package !~ /^$PRJ-(\d{8}-\d+-\w+?$/) ) { print "Error: Package name $Package doesn't match to PRJnn-YYYYMMDD-nnnn format\n"; exit 1; } else { $packageend = $1; } Best Regards, Alena ... |
| 17.03.2005, 16:44 |
(Perl) Help
try to rreplace this string alenab if ( $Package !~ /^$PRJ-(\d{8}-\d+-\w+?$/) ) { Alena with if ( $Package !~ /^$PRJ-(\d{8}-\d+-\w+?)$/) { :) ... |
| 17.03.2005, 17:19 |
(Perl) Help
Thanks a lot, it is work. I know, it is stupid to ask silly question... Any good advise abou book perl scripting without HTML stuff, we are using perl scripts for Harvest. It is just a pain to open a sxript with 4500 line and have not any good debugger for it! And I have 17 those scripts long like a hell! ... |
| 17.03.2005, 18:54 |
start [/forum/topic.php?fid=23&gotonew=1&tid=1478598]: |
154ms |
35ms |
| others: | 212ms |
| total: | 450ms |
