Некоректна работа function_exists('mysql...')
Код: php 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. выдает авторMYSQLi функции недоступны. MYSQL функции недоступны. OCI функции доступны. при этом MySQL прекрасно работает PHPINFO автор PHP Version 5.4.0 Build Date Feb 29 2012 19:20:16 Compiler MSVC9 (Visual C++ 2008) Architecture x86 Configure Command cscript /nologo configure.js "--enable-snapshot-build" "--disable-isapi" "--enable-debug-pack" "--disable-nsapi" "--without-mssql" "--without-pdo-mssql" "--without-pi3web" "--with-pdo-oci=C:\php-sdk\oracle\instantclient10\sdk,shared" "--with-oci8=C:\php-sdk\oracle\instantclient10\sdk,shared" "--with-oci8-11g=C:\php-sdk\oracle\instantclient11\sdk,shared" "--enable-object-out-dir=../obj/" "--enable-com-dotnet" "--with-mcrypt=static" "--disable-static-analyze" "--with-pgo" Server API Apache 2.4 Handler Apache Lounge Virtual Directory Support enabled Configuration File (php.ini) Path C:\WINDOWS Loaded Configuration File C:\usr\local\apache\conf\php.ini Scan this dir for additional .ini files (none) Additional .ini files parsed (none) PHP API 20100412 PHP Extension 20100525 Zend Extension 220100525 Zend Extension Build API220100525,TS,VC9 PHP Extension Build API20100525,TS,VC9 Debug Build no Thread Safety enabled Zend Signal Handling disabled Zend Memory Manager enabled Zend Multibyte Support disabled IPv6 Support enabled DTrace Support disabled Registered PHP Streams php, file, glob, data, http, ftp, zip, compress.zlib, phar Registered Stream Socket Transports tcp, udp Registered Stream Filters convert.iconv.*, mcrypt.*, mdecrypt.*, string.rot13, string.toupper, string.tolower, string.strip_tags, convert.*, consumed, dechunk, zlib.* .... mysqlnd mysqlnd enabled Version mysqlnd 5.0.10 - 20111026 - $Revision: 323634 $ Compression supported SSL supported Command buffer size 4096 Read buffer size 32768 Read timeout 31536000 Collecting statistics Yes Collecting memory statistics No Tracing n/a Loaded plugins mysqlnd,example,debug_trace,auth_plugin_mysql_native_password,auth_plugin_mysql_clear_password API Extensions no value Казалось бы не работает и не работает кому оно надо Но вот joomla категорически не видит мускуль так как определяет его наличие именно через function_exists Код: php 1. 2. 3. 4. 5. 6. 7. Как победить есть мысли? ... |
| 24.10.2012, 08:30:35 |
start [/forum/topic.php?fid=23&gotonew=1&tid=1464531]: |
167ms |
43ms |
| others: | 238ms |
| total: | 499ms |
