strtotime() и date() странно преобразуют даты
Есть такой простенький код. Код: php 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. Вот результат его работы: 26.12.10 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in D:\WebServers\home\localhost\www\syst\Ora2MySQL\date_bug.php on line 4 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in D:\WebServers\home\localhost\www\syst\Ora2MySQL\date_bug.php on line 4 2010-12-26 00:00:00 19.11.06 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in D:\WebServers\home\localhost\www\syst\Ora2MySQL\date_bug.php on line 9 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in D:\WebServers\home\localhost\www\syst\Ora2MySQL\date_bug.php on line 9 2013-10-31 19:11:06 Вопрос: почему 2010-й год конвертируется нормально, а 2006-й год превращается в 2013 ? ... |
| 31.10.2013, 09:58 |
P.S. Предупреждения о таймзоне убрал, вставив строку Код: php 1. Но проблему с конвертацией даты это не решило. ... |
| 31.10.2013, 10:05 |
| 31.10.2013, 11:46 |
start [/forum/topic.php?fid=23&gotonew=1&tid=1463320]: |
27ms |
49ms |
| others: | 204ms |
| total: | 333ms |
