USe xmlrpclib .Ошибка аутификации в Python
Подскажите, пожалуйста, что не так ( #!/usr/bin/python # -*- coding: utf-8 -*- import sys import xmlrpclib print "step 1 " username = '' password = '' url = " http://portal" Server = xmlrpclib.ServerProxy(url + '/rpc/xmlrpc') token = Server.confluence2.login(username, password) print "step 2" автор Traceback (most recent call last): File "C:/Python26/token.py", line 18, in <module> token = Server.confluence2.login(username, password) File "C:\Python26\lib\xmlrpclib.py", line 1199, in __call__ return self.__send(self.__name, args) File "C:\Python26\lib\xmlrpclib.py", line 1489, in __request verbose=self.__verbose File "C:\Python26\lib\xmlrpclib.py", line 1243, in request headers ProtocolError: <ProtocolError for portal.tander/rpc/xmlrpc: 301 Moved Permanently> Спастбо ... |
| 28.01.2014, 11:14 |
Станислав КлевцовПодскажите, пожалуйста, что не так ( #!/usr/bin/python # -*- coding: utf-8 -*- import sys import xmlrpclib print "step 1 " username = '' password = '' url = " http://portal" Server = xmlrpclib.ServerProxy(url + '/rpc/xmlrpc') token = Server.confluence2.login(username, password) print "step 2" авторTraceback (most recent call last): File "C:/Python26/token.py", line 18, in <module> token = Server.confluence2.login(username, password) File "C:\Python26\lib\xmlrpclib.py", line 1199, in __call__ return self.__send(self.__name, args) File "C:\Python26\lib\xmlrpclib.py", line 1489, in __request verbose=self.__verbose File "C:\Python26\lib\xmlrpclib.py", line 1243, in request headers ProtocolError: <ProtocolError for portal.tander/rpc/xmlrpc: 301 Moved Permanently> Спастбо Всем спасибо. Больше неактуально ! ... |
| 28.01.2014, 15:27 |
start [/forum/topic.php?fid=23&gotonew=1&tid=1463101]: |
172ms |
29ms |
| others: | 210ms |
| total: | 454ms |
