PHP Version 5.3.13 + MS SQL 2005
Apache/2.2.22 (Win32) mod_ssl/2.2.22 OpenSSL/1.0.1c PHP/5.3.13 Server at localhost Port 80 Подскажите как подключить ... |
| 22.10.2014, 06:21 |
g в пхп.ини добавил extension=php_sqlsrv_53_ts_vc9.dll extension=php_pdo_sqlsrv_53_ts_vc9.dll в екст их положил пробую так Код: php 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. долго думает и пишет Fatal error: Maximum execution time of 30 seconds exceeded in Z:\home\highgraf.ru\www\sqlsrv.php on line 10 ... |
| 22.10.2014, 06:37 |
собсна ругается Connection could not be established. Array ( [0] => Array ( [0] => IMSSP [SQLSTATE] => IMSSP [1] => -49 [code] => -49 [2] => This extension requires either the Microsoft SQL Server 2008 Native Client (SP1 or later) or the Microsoft SQL Server 2008 R2 Native Client ODBC Driver to communicate with SQL Server. Neither of those ODBC Drivers are currently installed. Access the following URL to download the Microsoft SQL Server 2008 R2 Native Client ODBC driver for x86: http://go.microsoft.com/fwlink/?LinkId=163712 [message] => This extension requires either the Microsoft SQL Server 2008 Native Client (SP1 or later) or the Microsoft SQL Server 2008 R2 Native Client ODBC Driver to communicate with SQL Server. Neither of those ODBC Drivers are currently installed. Access the following URL to download the Microsoft SQL Server 2008 R2 Native Client ODBC driver for x86: http://go.microsoft.com/fwlink/?LinkId=163712 ) [1] => Array ( [0] => IM002 [SQLSTATE] => IM002 [1] => 0 [code] => 0 [2] => [Microsoft] ... |
| 22.10.2014, 08:10 |
des1roer, амнезия? ... |
| 22.10.2014, 10:37 |
авторAccess the following URL to download the Microsoft SQL Server 2008 R2 Native Client ODBC driver for x86: http://go.microsoft.com/fwlink/?LinkId=163712 ... |
| 22.10.2014, 13:26 |
точняг амнезия))) думал что 2000 и 2005 по разному лечатся, а оказалось одно и тоже. ... |
| 22.10.2014, 14:26 |
есть еще люди добрые? времена денвера пронеслись как счастливвые детские годы. на сцену вышел апач на centos. немного потнацевав с бубном смогли поставить pdo_odbc и freeTDS. вопрос в следующем - как вывыести русские буквы? ... |
| 28.11.2014, 13:12 |
start [/forum/topic.php?fid=23&gotonew=1&tid=1462221]: |
166ms |
36ms |
| others: | 242ms |
| total: | 486ms |
