Море ошибок
Добрый день. Сорь за название темы, не знал, что написать. Хочу поставить eam системку, написанную на php (CalemEAM). Установил Apache, PHP, MySQL. Настроил их, запускаю установку CalemEAM, все ок, но доходит до момента проверки установленных компонент, пишет нет PDO для MySQL. Хотя библиотека лежит, в php.ini все прописано. Вывожу на экран phpinfo и вижу, что не грузится конфиг php.ini. В httpd.conf добавляю PHPIniDir C:/php. Вижу сл. строки: авторConfiguration File (php.ini) Path C:\Windows Loaded Configuration File C:\php\php.ini Я так понимаю, конфиг загрузился. Запускаю установку CalemEAM и вижу целую кучу ошибок вида: Deprecated: Non-static method LoggerLog::debug() should not be called statically, assuming $this from incompatible context in C:\Apache24\htdocs\CalemEAM\server\include\log4php\helpers\LoggerOptionConverter.php on line 303 Deprecated: Non-static method LoggerLog::log() should not be called statically, assuming $this from incompatible context in C:\Apache24\htdocs\CalemEAM\server\include\log4php\LoggerLog.php on line 71 Deprecated: Non-static method LoggerLog::internalDebugging() should not be called statically, assuming $this from incompatible context in C:\Apache24\htdocs\CalemEAM\server\include\log4php\LoggerLog.php on line 49 Deprecated: Non-static method LoggerLog::debug() should not be called statically, assuming $this from incompatible context in C:\Apache24\htdocs\CalemEAM\server\include\log4php\helpers\LoggerOptionConverter.php on line 306 Deprecated: Non-static method LoggerLog::log() should not be called statically, assuming $this from incompatible context in C:\Apache24\htdocs\CalemEAM\server\include\log4php\LoggerLog.php on line 71 Deprecated: Non-static method LoggerLog::internalDebugging() should not be called statically, assuming $this from incompatible context in C:\Apache24\htdocs\CalemEAM\server\include\log4php\LoggerLog.php on line 49 Deprecated: Non-static method LoggerLayout::factory() should not be called statically, assuming $this from incompatible context in C:\Apache24\htdocs\CalemEAM\server\include\log4php\LoggerPropertyConfigurator.php on line 618 Deprecated: Non-static method LoggerLog::debug() should not be called statically, assuming $this from incompatible context in C:\Apache24\htdocs\CalemEAM\server\include\log4php\LoggerPropertyConfigurator.php on line 629 Deprecated: Non-static method LoggerLog::log() should not be called statically, assuming $this from incompatible context in C:\Apache24\htdocs\CalemEAM\server\include\log4php\LoggerLog.php on line 71 Deprecated: Non-static method LoggerLog::internalDebugging() should not be called statically, assuming $this from incompatible context in C:\Apache24\htdocs\CalemEAM\server\include\log4php\LoggerLog.php on line 49 Deprecated: Non-static method LoggerPropertySetter::setPropertiesByObject() should not be called statically, assuming $this from incompatible context in C:\Apache24\htdocs\CalemEAM\server\include\log4php\LoggerPropertyConfigurator.php on line 633 Deprecated: Non-static method LoggerLog::debug() should not be called statically, assuming $this from incompatible context in C:\Apache24\htdocs\CalemEAM\server\include\log4php\config\LoggerPropertySetter.php on line 99 если функции объявить как public static, ошибка пропадает, но их так много, что не считаю это решением. Ведь до чтения конфига все работало. В чем косяк, подскажите в каком направлении смотреть? ... |
| 13.02.2015, 17:20 |
Море ошибок
Супер_ПавВ чем косяк, подскажите в каком направлении смотреть? на php.ini - error_reporting ... |
| 13.02.2015, 17:26 |
Море ошибок
мерси, помогло! Правда PDO Driver for MySQL так и не видит. Но это уже отдельная история, попробую сам разобраться! ... |
| 13.02.2015, 17:39 |
Море ошибок
Супер_Пав, а из командной строчки php без ругани запускается? ... |
| 13.02.2015, 17:42 |
Море ошибок
что значит пхп запускает? Вообщем очень забавная тема. Комментирую текст: автор;error_reporting ; Default Value: E_STRICT & ~E_DEPRECATED ; Development Value: E_STRICT & ~E_DEPRECATED ; Production Value: E_DEPRECATED & ~E_STRICT Проверка компонент проходит, но при этом валится куча ошибок. Но главное появляется кнопка Далее. Возвращаюсь в php.ini, снимаю комментарий, перезапускаю апач, наживаю в установке Далее. Все проходит, ошибок нет. Наступает шаг Настройка БД. Указываю параметры БД, нажимаю далее, пишет не найден драйвер...какой не пишет. С error_reporting делаю теже действия, что и в начале сообщения. Еще раз нажимаю Далее, проходит. Что-то создает, добавляет, валится море сообщений. Но главное все проходит) Мне казалось, что error_reporting отвечает за отчет об ошибках и т.д. но никак за проверку наличия PDO ... |
| 13.02.2015, 18:25 |
start [/forum/topic.php?fid=23&gotonew=1&tid=1462001]: |
78ms |
53ms |
| others: | 238ms |
| total: | 429ms |
