exist(): Error: File doesn't exist: "./../../modul/template/form.tpl.htm"! Pattern cl
Подскажите что за проблема, что к чему обращается и что чегото не находит: <?php class template { var $ver = "Pattern class"; var $filelist = array(), $assign = array(); var $root, $arr, $delimiters; function init($arr = "", $root = "", $delimit = "") { if (empty($arr) || !is_array($arr)) $this->killme("init(): Gimme an associative array first"); $this->setroot($root); $this->listit($arr); if (!empty($delimit)) { if (preg_match ("/^.{2}$/i",$delimit)) { $this->delimiters = $delimit[0]; $this->delimiters = $delimit[1]; } else $this->killme("Specify only two chars for delimiter!"); } else $this->delimiters(); } function exist($arr){ while (list($var1, $file) = each ($arr)) if (!file_exists($file)) $this->killme("exist(): Error: File doesn't exist: \"$file\"!\n"); } function setroot($root = "") { if (is_string($root)) { $this->root = preg_replace ("/([^\/])$/", "\\1/", (empty($root) ? "./" : $root)); if (!is_dir($this->root)) $this->killme("setroot(): $this->root is not a directory!"); } else $this->killme("setroot(): Specified parameter for setroot() is not a string!\n"); } function killme($msg = "") { die ((empty($msg)?"killed":$msg)."<br>\n".$this->ver); } function assign($arr = "", $val = "") { if (empty($arr)) $this->killme("assign(): no given parameters"); if (!is_array($arr)) $this->assign["$arr"] = $val; else while (list($key, $val) = each ($arr)) if (!empty($key)) $this->assign["$key"] = $val; } function listit($list = "") { if (!is_array($list) || empty($list)) $this->killme("listit(): template filelist is empty!"); else { while(list($descr, $file) = each($list)) if (!empty($descr)) $this->filelist["$descr"] = $this->root.$file; $this->exist($this->filelist); } } function parseit($data = "", $temp = "") { if (empty($data)) $this->killme("parseit(): Dunno what to do!"); $f = (!empty($this->filelist["$data"])) ? file($this->filelist["$data"]) : $data; if (!empty($temp)) { $this->assign["$temp"] .= $this->getparsed($f); } else { $this->arr .= $this->getparsed($f); } } function getparsed($data = "") { if (empty($data)){ $this->killme("getparsed(): Gimme some data to parse it :)"); } if (is_array($data)){ $data = implode("", $data); } reset($this->assign); while (list($key, $val) = each ($this->assign)) { $data = preg_replace("/".$this->delimiters[0]."\s*". preg_quote($key)."\s*".$this->delimiters[1]."/", "$val", $data); } return $data; } function delimiters($d1 = "", $d2 = "") { if (!empty($d1) && !empty($d2)) { $this->delimiters[0] = preg_quote($d1); $this->delimiters[1] = preg_quote($d2); } else { $this->delimiters[0] = preg_quote("{"); $this->delimiters[1] = preg_quote("}"); } } function addtolist ($d = "", $name = "") { if (empty($d) || !is_string($name)) $this->killme("addtolist: Descriptor or filename is not a string!"); else { if (!empty($d) && !empty($name)) { $this->filelist["$d"] = $this->root.$name; $this->exist($this->filelist); } else $this->killme("addtolist: Descriptor or filename is empty!"); } } function freshall() { while(list($descr, $file) = each($this->filelist)) unset($this->filelist["$descr"]); while(list($descr, $tag) = each($this->assign)) unset($this->filelist["$tag"]); unset($this->root); unset($this->arr); } function fresh() { unset($this->arr); } function printit($me = "") { echo (empty($me)?$this->arr : $me); } function printitd($me = "") { return (empty($me)?$this->arr : $me); } function printit2(){ include_once "./session.php"; $arr_local=preg_replace("/\<\?php/","<?php_my",$this->arr); $arr_local=preg_split("/(\<\?php|\?\>)/",$arr_local); $n=count($arr_local); for($i=0; $i<$n; $i++){ $stroka=ltrim($arr_local[$i]); if(trim($stroka)!="" or empty($stroka)){ if(substr($stroka,0,3)=="_my"){ eval(substr($stroka,3,strlen($stroka)).";"); }else{ echo $stroka; } } } } function retArg(){ return $this->arr; } function clear(){ $this->arr = preg_replace("/".$this->delimiters[0]."\s*(.*)\s*".$this->delimiters[1]."/", "",$this->arr); } } ?> ... |
| 04.09.2015, 16:18 |
Romantiktj, оформляйте код специальными тегами (кнопка SRC). Смотрите, что передается классу, вы пытаетесь скормить ему не существующий файл, либо путь до него не верный. Черным по белому же вам пишут "File doesn't exist: "./../../modul/template/form.tpl.htm"" - мол файл не найден, и даже путь показали. ... |
| 04.09.2015, 16:28 |
start [/forum/topic.php?fid=23&gotonew=1&tid=1461553]: |
156ms |
42ms |
| others: | 229ms |
| total: | 463ms |
