Не работает tinymce 3.2
Привет всем. Почему то не работает этот редактор на сервере. Если просто перетащить файл на браузер - редактор отображается, а на сервере лишь textarea. Посмотрел лог, есто вот такие ошибки: [Mon Nov 23 05:12:15 2009] [warn] Init: SSL server IP/port conflict: 123.my_admin:443 (Z:/usr/local/apache/conf/vhosts.conf:130) vs. vova.lan:443 (Z:/usr/local/apache/conf/vhosts.conf:590) [Mon Nov 23 05:12:15 2009] [warn] Init: SSL server IP/port conflict: 123.bosyy.ua:443 (Z:/usr/local/apache/conf/vhosts.conf:107) vs. vova.lan:443 (Z:/usr/local/apache/conf/vhosts.conf:590) [Mon Nov 23 05:12:15 2009] [warn] Init: SSL server IP/port conflict: 11.bosyy-blog.ua:443 (Z:/usr/local/apache/conf/vhosts.conf:84) vs. vova.lan:443 (Z:/usr/local/apache/conf/vhosts.conf:590) [Mon Nov 23 05:12:15 2009] [warn] Init: SSL server IP/port conflict: 1:443 (Z:/usr/local/apache/conf/vhosts.conf:61) vs. vova.lan:443 (Z:/usr/local/apache/conf/vhosts.conf:590) [Mon Nov 23 05:12:15 2009] [warn] Init: SSL server IP/port conflict: localhost:443 (Z:/usr/local/apache/conf/vhosts.conf:38) vs. vova.lan:443 (Z:/usr/local/apache/conf/vhosts.conf:590) [Mon Nov 23 05:12:15 2009] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!! [Mon Nov 23 05:12:15 2009] [notice] Child 12124: Child process is running [Mon Nov 23 05:12:15 2009] [notice] Child 12124: Acquired the start mutex. [Mon Nov 23 05:12:15 2009] [notice] Child 12124: Starting 250 worker threads. [Mon Nov 23 05:12:15 2009] [notice] Child 12124: Starting thread to listen on port 443. [Mon Nov 23 05:12:15 2009] [notice] Child 12124: Starting thread to listen on port 8648. [Mon Nov 23 05:12:15 2009] [notice] Child 12124: Starting thread to listen on port 80. [Mon Nov 23 05:12:15 2009] [notice] Child 12124: Starting thread to listen on port 443. [Mon Nov 23 05:29:10 2009] [error] [client 127.0.0.1] File does not exist: Z:/home/my_admin/www/favicon.ico, referer: http://my_admin/cms/main.php?part=about В чем проблема? Заранее спасибо. ... |
| 23.11.2009, 06:35 |
start [/forum/topic.php?fid=22&gotonew=1&tid=1453923]: |
160ms |
| others: | 246ms |
| total: | 460ms |
