extjs и закруглённые углы
Подскажите, как задавать закруглить уголки у панели (xtype: panel) ? ... |
| 18.07.2012, 23:17:26 |
ExtJS не знаю может, Вам пригодится http://htmlbook.ru/css/border-radius ... ... |
| 18.07.2012, 23:40:16 |
Ichisen, Код: javascript 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. ... |
| 22.07.2012, 06:11:36 |
здравствуйте, а у кнопки можно углы скруглить? как? ... |
| 22.07.2012, 07:03:43 |
катастрофа, http://www.objis.com/formationextjs/lib/extjs-4.0.0/docs/api/Ext.button.Button.html frame : Boolean Specify as true to have the Component inject framing elements within the Component at render time to provide a graphical rounded frame around the Component content. This is only necessary when running on outdated, or non standard-compliant browsers such as Microsoft's Internet Explorer prior to version 9 which do not support rounded corners natively. The extra space taken up by this framing is available from the read only property frameSize. ... |
| 22.07.2012, 07:51:20 |
start [/forum/topic.php?fid=22&gotonew=1&tid=1449554]: |
43ms |
43ms |
| others: | 206ms |
| total: | 341ms |
