flexslider настройка
#38979676
Ссылка:
Вот код
1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79. 80. 81. 82. 83. 84. 85. 86. 87. 88. 89. 90. 91. 92. 93. 94. 95. 96. 97. 98. 99. 100. 101. 102. 103. 104. 105. 106. 107. 108. 109. 110. 111. 112. 113. 114. 115. 116. 117. 118. 119. 120. 121.
/* Browser Resets
.flex-container a:active,
.flexslider a:active,
.flex-container a:focus,
.flexslider a:focus {outline: none;}
.flex-control-nav,
.flex-direction-nav {margin: 0; padding: 0; list-style: none;}
/* Icon Fonts
/* Font-face Icons */
@font-face {
font-family: 'flexslider-icon';
src:url('fonts/flexslider-icon.eot');
src:url('fonts/flexslider-icon.eot?#iefix') format('embedded-opentype'),
url('fonts/flexslider-icon.woff') format('woff'),
url('fonts/flexslider-icon.ttf') format('truetype'),
url('fonts/flexslider-icon.svg#flexslider-icon') format('svg');
font-weight: normal;
font-style: normal;
/* FlexSlider Necessary Styles
.flexslider {margin: 0; padding: 0;}
.flexslider .slides > li {display: none; -webkit-backface-visibility: hidden;} /* Hide
the slides before the JS is loaded. Avoids image jumping */
.flexslider .slides img {width: 100%; display: block;}
.flex-pauseplay span {text-transform: capitalize;}
/* Clearfix for the .slides element */
.slides:after {content: "."; display: block; clear: both; visibility: hidden; line-
height: 0; height: 0;}
html[xmlns] .slides {display: block;}
* html .slides {height: 1%;}
/* No JavaScript Fallback */
/* If you are not using another script, such as Modernizr, make sure you
* include js that eliminates this class on page load */
.no-js .slides > li:first-child {display: block;}
/* FlexSlider Default Theme
.flexslider { margin: 60 0 0px; position: relative; zoom: 1; }
.loading .flex-viewport { max-height: 100px; }
.flexslider .slides { zoom: 1; }
.carousel li { margin-right: 5px; }
/* Direction Nav */
.flex-direction-nav {*height: 0;}
.flex-direction-nav a { text-decoration:none; display: block; width: 40px; height:
40px; margin: -20px 0 0; position: absolute; top: 50%; z-index: 10; overflow: hidden;
opacity: 0; cursor: pointer; color: rgba(0,0,0,0.8); text-shadow: 1px 1px 0 rgba
(255,255,255,0.3); -webkit-transition: all .3s ease; -moz-transition: all .3s ease;
transition: all .3s ease; }
.flex-direction-nav .flex-prev { left: -50px; }
.flex-direction-nav .flex-next { right: -50px; text-align: right; }
.flexslider:hover .flex-prev { opacity: 0.7; left: 10px; }
.flexslider:hover .flex-next { opacity: 0.7; right: 10px; }
.flexslider:hover .flex-next:hover, .flexslider:hover .flex-prev:hover { opacity: 1; }
.flex-direction-nav .flex-disabled { opacity: 0!important; filter:alpha(opacity=0);
cursor: default; }
.flex-direction-nav a:before { font-family: "flexslider-icon"; font-size: 40px;
line-height:1; display: inline-block; content: '\f001'; }
.flex-direction-nav a.flex-next:before { content: '\f002'; }
/* Pause/Play */
.flex-pauseplay a { display: block; width: 20px; height: 20px; position: absolute;
bottom: 5px; left: 10px; opacity: 0.8; z-index: 10; overflow: hidden; cursor: pointer;
color: #000; }
.flex-pauseplay a:before { font-family: "flexslider-icon"; font-size: 20px; display:
inline-block; content: '\f004'; }
.flex-pauseplay a:hover { opacity: 1; }
.flex-pauseplay a.flex-play:before { content: '\f003'; }
/* Control Nav */
.flex-control-nav {width: 100%; position: absolute; bottom: -40px; text-align:
center;}
.flex-control-nav li {margin: 0 6px; display: inline-block; zoom: 1; *display:
inline;}
.flex-control-paging li a {width: 11px; height: 11px; display: block; background:
#666; background: rgba(0,0,0,0.5); cursor: pointer; text-indent: -9999px; -webkit-
border-radius: 20px; -moz-border-radius: 20px; -o-border-radius: 20px; border-radius:
20px; -webkit-box-shadow: inset 0 0 3px rgba(0,0,0,0.3); -moz-box-shadow: inset 0 0
3px rgba(0,0,0,0.3); -o-box-shadow: inset 0 0 3px rgba(0,0,0,0.3); box-shadow: inset 0
0 3px rgba(0,0,0,0.3); }
.flex-control-paging li a:hover { background: #333; background: rgba(0,0,0,0.7); }
.flex-control-paging li a.flex-active { background: #000; background: rgba(0,0,0,0.9);
cursor: default; }
.flex-control-thumbs {margin: 5px 0 0; position: static; overflow: hidden;}
.flex-control-thumbs li {width: 25%; float: left; margin: 0;}
.flex-control-thumbs img {width: 100%; display: block; opacity: .7; cursor: pointer;}
.flex-control-thumbs img:hover {opacity: 1;}
.flex-control-thumbs .flex-active {opacity: 1; cursor: default;}
@media screen and (max-width: 860px) {
.flex-direction-nav .flex-prev { opacity: 1; left: 10px;}
.flex-direction-nav .flex-next { opacity: 1; right: 10px;}
