Help with debugging errors
Hi, I'm new to Flare, using the 9.1 trial version. Larger issue aside, I have just edited the XML and am now seeing an error "Warning: Invalid syntax in or near " tag on line 59" I cannot select the error to google it, I cannot view a log that might show more context, and Flare is giving me no help in trying to locate the error in the XML. I need a hint to get started, such as how can I google the error? (Typing the error into google didn't do much good but it would be better if I didn't have to do that.) What assistance does Flare provide trying to debug errors like this? Please help. I didn't find the right solution from the Internet. References:- https://bit.ly/2IzPYRm Creative production service Thanks ... |
| 21.05.2018, 13:03:51 |
start [/forum/topic.php?fid=22&gotonew=1&tid=1444174]: |
191ms |
| others: | 239ms |
| total: | 492ms |
