Combo box fill problem
pochemu pri navigacii ot odnoj zapisi k drugoj, jesli znachenije CustomerOrderID = is null, v combobox pojavljajentsja ne pustoje znachenije, a prisvaivajetsja 1je iz spiska comboboxa? kak sdelat', chto by otobrazhenije bylo korrektnym? Dim da1 As SqlClient.SqlDataAdapter = New SqlClient.SqlDataAdapter(cmdString, myConnection) Dim dataSet2 As DataSet = New DataSet() da1.Fill(dataSet2, "OurCustomers") With Me.CustomerID .DataSource = dataSet2.Tables("OurCustomers") .ValueMember = "ID" .DisplayMember = "CompName" End With Me.CustomerID.DataBindings.Add("selectedvalue", DsOrdersSql2, "Orders.CustomerOrderID") ... |
| 20.08.2004, 18:35 |
Ну попробуй сделать SQL-запрос не таким простым, как ты сделал, а с проверкой iif(isnull(),,) Max Pro ... |
| 20.08.2004, 19:24 |
start [/forum/topic.php?fid=20&gotonew=1&tid=1438539]: |
60ms |
49ms |
| others: | 231ms |
| total: | 387ms |
