Новый кодогенератор
Наткнулся сегодня на бесплатный кодогенератор Sculpture с неплохим набором: DAAB, NHibernate, LINQ, CSLA, WCF, ASMX, Windows forms, WPF, Silverlight, ASP.NET, & ASP.NET MVC ... |
03.12.2008, 16:17 |
Новый кодогенератор
What is Sculpture? * Sculpture is a .NET open source Model-Driven Development code generation framework ideal for creating and managing .NET Enterprise Applications. * With Sculpture you can model your application components, and then transform this model to deployable components with your favorite technology. * Sculpture comes with a host of ready-made Molds (The word “Molds” comes from Molding) like (DAAB, NHibernate, LINQ, CSLA, WCF, ASMX, Windows forms, WPF, Silverlight, ASP.NET, & ASP.NET MVC). * Sculpture provides starter kit wizard enables choosing among available technologies to start your project with all layers in no time. * Sculpture doesn't force you to adhere to a specific architecture, it contains a guidance package for building your own Mold or customizes existing ones. If you have a custom architecture, using this guidance package you can build a custom code generator with your favorite technology. * Sculpture can generate any kind of text output using templates (source code, database scripts, web pages, XML, configuration files, etc.). * Sculpture takes you to the next level of abstraction by separating the problem from the implementation technology. * Sculpture takes you to the domain specific programming by adding your specifications to the model environment and the generated code. ... |
03.12.2008, 16:24 |
Новый кодогенератор
А есть какая-нибудь хорошая генерилка для CSLA на базе движка от www.mygenerationsoftware.com ? для NH с наследованием приходилось самому делать хотелось бы для CSLA->NH найти что-нибудь готовое и очень настраиваемое SeVa, Вы наверно знаете какие-нибудь хорошие примеры CSLA->NH? ... |
09.03.2013, 07:12 |
Новый кодогенератор
sanyock2хотелось бы для CSLA->NH найти что-нибудь готовое вдруг, кому-нибудь: http://cslacontrib.codeplex.com/SourceControl/changeset/view/46985#302175 http://stackoverflow.com/questions/789537/csla-net-v3-6-nhibernate-v2-10-how-to-overcome-need-for-vitual-properties ... |
10.03.2013, 08:50 |
start [/forum/topic.php?fid=20&gotonew=1&tid=1405039]: |
52ms |
47ms |
others: | 309ms |
total: | 468ms |
0 / 0 |
