Output: compress the file with the directory, but i need just the compressed file.
public void Main() { string folderDirectory = Dts.Variables["dirDestinationFolder"].Value.ToString(); string fileName = "Report " + Dts.Variables["varEndDate"].Value.ToString() + ".xls"; CompressReportsFolder(fileName, folderDirectory); Dts.TaskResult = (int)ScriptResults.Success; } public void CompressReportsFolder(string fileName, string folderDirectory) { ZipFile zip = new ZipFile(); string strOriginFilewithPath = folderDirectory + fileName; zip.AddFile(strOriginFilewithPath); string strCompressedFilewithPath = folderDirectory + fileName.Replace(".xls", ".zip"); zip.Save(strCompressedFilewithPath); } Output: compress the file with the directory, but i need just the compressed file. Thanks ... |
30.05.2013, 23:00 |
start [/forum/topic.php?fid=20&gotonew=1&tid=1404593]: |
66ms |
45ms |
others: | 11ms |
total: | 175ms |
0 / 0 |
