Форумы / WinForms, .Net Framework [игнор отключен] [закрыт для гостей] / Проблемы с кодом!
6 сообщений из 6, страница 1 из 1
Проблемы с кодом!
    #38890924
DKasimov
Народ привет!
Я вообще с VB дружу немного, а так занимаюсь СУБД, но тут возникла проблема!
Есть код:
Imports Microsoft.VisualBasic
Imports System
Imports System.Windows.Forms
Imports Sherp
Namespace UserForm
Public Class EGRUL_PROJECT_NEW
Public connection As System.Data.SqlClient.SqlConnection
Public AnotherThreadStop As Boolean = False
Public IsUpload As Boolean = False
Public Thread1 As System.Threading.Thread
Public archWithExtension As String = ""
Public FileName As String = ""
Public FileFullName As String = ""
Public FileUploadNumber As Int32 = 0
Private Sub btn_choice_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btn_choice.Click
Dim dlg As New System.Windows.Forms.OpenFileDialog
dlg.Filter = "RAR файлы (*.rar)|*.rar|ZIP файлы (*.zip)|*.zip"
If dlg.ShowDialog() = Windows.Forms.DialogResult.OK Then
foldername.Text = dlg.FileName
End If
End Sub
Private Sub btn_download_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btn_download.Click
If Me.foldername.Text = "" Then
MsgBox("Выберите архив!", MsgBoxStyle.Critical, "Ошибка")
Exit Sub
End If
Dim arch As System.IO.FileInfo = New System.IO.FileInfo(TextBoxGetText(foldername))
Dim FileName As String = Mid(arch.Name, 1, Len(arch.Name) - Len(arch.Extension))
Dim dir As System.IO.DirectoryInfo = New System.IO.DirectoryInfo(arch.DirectoryName & "\" & FileName & "\")
If dir.Exists Then
Try
Kill(arch.DirectoryName & "\" & FileName & "\" & "\*.*")
Catch ex As Exception
End Try
Try
dir.Delete()
End Try
Else
dir.Create()
End If
connection = New System.Data.SqlClient.SqlConnection(Me.connstr.Text)
Try
If connection.State = System.Data.ConnectionState.Closed Then
connection.Open()
End If
MsgBox(ex.Message, MsgBoxStyle.Critical, "Ошибка")
Exit Sub
End Try
AnotherThreadStop = False
Try
Thread1 = New System.Threading.Thread(AddressOf AnotherThread)
Thread1.Start()
Catch
End Try
End Sub
Public Sub AnotherThread()
Dim command1 As System.Data.SqlClient.SqlCommand = New System.Data.SqlClient.SqlCommand("dbo.FileInWork_u", connection)
command1.CommandType = System.Data.CommandType.StoredProcedure
command1.CommandTimeout = 0
GetSqlParameters(command1)
connection.Open()
End If
command1.Parameters("@Action").Value = 7
command1.Parameters("@FileName").Value = ""
If command1.ExecuteScalar() = "0,7" Then
MsgBox("Запущена процедура удаления дубликатов записей, ждите завершения!", MsgBoxStyle.Critical, "Загрузка файлов EGRUL невозможна")
Exit Sub
End If
archWithExtension = Mid(arch.Name, 1, Len(arch.Name) - Len(arch.Extension))
Dim dir As System.IO.DirectoryInfo = New System.IO.DirectoryInfo(arch.DirectoryName & "\" & archWithExtension & "\")
Try
Dim myProcess As New System.Diagnostics.Process
SetText(Label1, "Распаковка архива " & arch.Name)
Dim iswinrar As String = ""
iswinrar = My.Computer.Registry.GetValue("HKEY_CLASSES_ROOT\WinRAR\shell\open\command", "", Nothing)
If iswinrar = "" Then
SetText(Label1, "Архиватор Winrar не установлен в системе!" & arch.Name)
Exit Sub
End If
Dim f As System.IO.FileInfo = New System.IO.FileInfo(iswinrar.Substring(1, InStr(iswinrar, """%") - 4))
If f.Exists = False Then
SetText(Label1, "winrar.exe не найден в директории " + f.DirectoryName)
Exit Sub
End If
Dim f1 As System.IO.FileInfo = New System.IO.FileInfo(f.DirectoryName + "\WINRAR.EXE")
If f1.Exists = True Then
Dim startInfo As New System.Diagnostics.ProcessStartInfo(f1.FullName)
startInfo.WindowStyle = System.Diagnostics.ProcessWindowStyle.Hidden
startInfo.Arguments = " e -ibck -o+ -inul " + arch.FullName + " " + dir.FullName
myProcess = System.Diagnostics.Process.Start(startInfo)
myProcess.WaitForExit()
Else
SetText(Label1, "unrar.exe не найден в директории " + f1.DirectoryName)
Exit Sub
End If
SetText(Label1, "Архив " & arch.Name & " распакован успешно")
SetText(Label1, "Ошибка распаковки архива " & arch.Name)
Exit Sub
End Try
Dim strError As String = ""
Try
ProgressBarSetValue(ProgressBar1, 0)
SetEnabled(btn_choice, False)
SetEnabled(btn_download, False)
SetMaximum(ProgressBar1, dir.GetFiles("*.xml", IO.SearchOption.AllDirectories).Length)
Application.DoEvents()
If AnotherThreadStop = True Then
Exit Sub
End If
For Each FileXML As System.IO.FileInfo In dir.GetFiles("*.xml", IO.SearchOption.AllDirectories)
Exit Sub
End If
IsUpload = True
ProgressBarSetValue(ProgressBar1, ProgressBarGetValue(ProgressBar1) + 1)
SetText(Label1, "Загрузка файла " + FileXML.Name + ": " + ProgressBarGetValue(ProgressBar1).ToString + " из " + dir.GetFiles("*.xml", IO.SearchOption.AllDirectories).Length.ToString)
FileName = FileXML.Name
FileFullName = FileXML.FullName
ProgressBarSetValue(ProgressBar2, 0)
Dim commandPROV As System.Data.SqlClient.SqlCommand = New System.Data.SqlClient.SqlCommand("dbo.FileInWork_u", connection)
commandPROV.CommandType = System.Data.CommandType.StoredProcedure
commandPROV.CommandTimeout = 0
GetSqlParameters(commandPROV)
connection.Open()
End If
commandPROV.Parameters("@Action").Value = 1
commandPROV.Parameters("@FileName").Value = FileXML.Name
If commandPROV.ExecuteScalar() = "0,1" Then
commandPROV = New System.Data.SqlClient.SqlCommand("dbo.FileInWork_u", connection)
commandPROV.Parameters("@Action").Value = 2
If commandPROV.ExecuteScalar() = "0,3" Then
commandPROV.Parameters("@Action").Value = 3
FileUploadNumber = commandPROV.ExecuteScalar()
ElseIf commandPROV.ExecuteScalar() = "0,4" Then
If connection.State = System.Data.ConnectionState.Open Then
connection.Close()
End If
Continue For
End If
ElseIf commandPROV.ExecuteScalar() = "0,2" Then
commandPROV.Parameters("@Action").Value = 4
End If
Dim commandStart As System.Data.SqlClient.SqlCommand = New System.Data.SqlClient.SqlCommand("dbo.FileInWork_u", connection)
commandStart.CommandType = System.Data.CommandType.StoredProcedure
commandStart.CommandTimeout = 0
GetSqlParameters(commandStart)
connection.Open()
End If
commandStart.Parameters("@Action").Value = 5
commandStart.Parameters("@FileName").Value = FileName
commandStart.ExecuteNonQuery()
Dim stream As IO.Stream = IO.File.Open(FileFullName, IO.FileMode.Open, IO.FileAccess.Read)
Try
Dim binReader As New IO.StreamReader(stream, System.Text.Encoding.Default)
Dim N As Integer = 2000000 'объем который мы читаем из файла
Dim Xbyte() As Char ' массив считаных символов из файла
Dim XMLResult As String ' Строка читаемая из файла
Dim s As String = "" ' остатки строки которую мы не обработали
Dim Valuemax As Integer = binReader.BaseStream.Length
Dim RABytes As Int64 = 0 ' сколько байт было прочитано
Dim RBytes As Int64 = 0 ' сколько байт надо прочитать
Dim SReturn As String = ""
SetText(Label2, "Обработка данных: " + (CInt(RABytes * 100 / Valuemax)).ToString + "%")
While Not binReader.EndOfStream
If binReader.BaseStream.Length - RABytes > N - s.Length Then
RBytes = N - s.Length
Else : RBytes = binReader.BaseStream.Length - RABytes
End If
ReDim Xbyte(RBytes - 1)
binReader.Read(Xbyte, 0, RBytes)
XMLResult = Nothing
XMLResult = Xbyte
XMLResult = XMLResult.Replace(Chr(63), "")
If Array.IndexOf(Xbyte, Nothing) > 0 Then
XMLResult = XMLResult.Substring(0, Array.IndexOf(Xbyte, Nothing))
End If
If XMLResult.IndexOf("<HEADER") >= 0 Then
XMLResult = XMLResult.Substring(XMLResult.IndexOf("</HEADER>") + 9, XMLResult.Length() - XMLResult.IndexOf("</HEADER>") - 9)
End If
XMLResult = s + XMLResult
While XMLResult <> ""
If XMLResult.IndexOf("<UL ") >= 0 Then
If XMLResult.IndexOf("</UL>") > 0 Then
SReturn = XMLResult.Substring(XMLResult.IndexOf("<UL "), XMLResult.IndexOf("</UL>") - XMLResult.IndexOf("<UL ") + 5)
Try
XMLResult = XMLResult.Substring(SReturn.Length + 2, XMLResult.Length() - SReturn.Length - 2)
XMLResult = XMLResult.Substring(SReturn.Length + 1, XMLResult.Length() - SReturn.Length - 1)
If XMLResult = "" Then
s = ""
End If
End Try
Dim commandFileXMLParsing As System.Data.SqlClient.SqlCommand = New System.Data.SqlClient.SqlCommand("dbo.EGRUL_FileXMLParsing", connection)
commandFileXMLParsing.CommandType = System.Data.CommandType.StoredProcedure
commandFileXMLParsing.CommandTimeout = 0
GetSqlParameters(commandFileXMLParsing)
connection.Open()
End If
commandFileXMLParsing.Parameters("@FileXMLText").Value = "<?xml version=""1.0"" encoding=""windows-1251""?>" + SReturn
commandFileXMLParsing.Parameters("@FileName").Value = FileName
commandFileXMLParsing.Parameters("@IdFile").Value = FileUploadNumber
Try
commandFileXMLParsing.ExecuteNonQuery()
Catch ex1 As Exception
MsgBox(FileFullName & vbCrLf & ex1.ToString(), MsgBoxStyle.Critical, "Ошибка")
stream.Close()
Exit Sub
End Try
connection.Close()
End If
Else
s = XMLResult
Exit While
End If
ElseIf XMLResult.IndexOf("<IP ") >= 0 Then
s = ""
Exit While
Else
s = XMLResult
Exit While
End If
End While
s = ""
End If
RABytes = RABytes + RBytes
ProgressBarSetValue(ProgressBar2, (CInt(RABytes * 100 / Valuemax)))
End While
stream.Close()
Dim commandEnd As System.Data.SqlClient.SqlCommand = New System.Data.SqlClient.SqlCommand("dbo.FileInWork_u", connection)
commandEnd.CommandType = System.Data.CommandType.StoredProcedure
commandEnd.CommandTimeout = 0
GetSqlParameters(commandEnd)
connection.Open()
End If
commandEnd.Parameters("@Action").Value = 6
commandEnd.Parameters("@FileName").Value = FileName
Try
commandEnd.ExecuteNonQuery()
Catch exEnd As Exception
End Try
stream.Close()
MsgBox("Ошибка: " & ex.Message, 16, "Внимание")
End Try
Next
Try
Kill(dir.FullName & "*.*")
End Try
dir.Delete()
SetText(Label1, "Директория " & arch.DirectoryName & "\" & archWithExtension & "\" & " успешно удалена")
MsgBox("The process failed: " & vbCrLf & "Ошибка в файле " & FileFullName & vbCrLf & ex.ToString(), MsgBoxStyle.Critical, "Ошибка")
Finally
Try
Kill(arch.DirectoryName & "\" & archWithExtension & "\" & "\*.*")
End Try
Try
dir.Delete()
End Try
TextBoxSetText(foldername, "")
SetText(Label1, "Статус обработки архива")
SetText(Label2, "Статус обработки данных XML файла")
SetEnabled(btn_choice, True)
SetEnabled(btn_download, True)
End Try
End Sub
Private Delegate Sub StDelegateTextBoxSetText(ByVal Info As TextBox, ByVal Text As String)
Private Sub TextBoxSetText(ByVal Info As TextBox, ByVal Text As String)
If (Info.InvokeRequired) Then
Dim la As StDelegateTextBoxSetText = New StDelegateTextBoxSetText(AddressOf TextBoxSetText)
Info.Invoke(la, New Object() {Info, Text})
Else
Info.Text = Text
End If
End Sub
Private Delegate Function StDelegateTextBoxGetText(ByVal Info As TextBox)
Private Function TextBoxGetText(ByVal Info As TextBox)
Dim la As StDelegateTextBoxGetText = New StDelegateTextBoxGetText(AddressOf TextBoxGetText)
Info.Invoke(la, New Object() {Info})
End If
Return Info.Text
End Function
Private Delegate Sub StDelegateLable(ByVal Info As Label, ByVal Text As String)
Private Sub SetText(ByVal Info As Label, ByVal Text As String)
Dim la As StDelegateLable = New StDelegateLable(AddressOf SetText)
Else
Info.Text = Text
End If
End Sub
Private Delegate Function StDelegateGetLableText(ByVal Info As Label)
Private Function LableGetText(ByVal Info As Label)
Dim la As StDelegateGetLableText = New StDelegateGetLableText(AddressOf LableGetText)
End If
Return Info.Text
End Function
Private Delegate Sub StDelegateProgressBarSetValue(ByVal Info As ProgressBar, ByVal value As Int32)
Private Sub ProgressBarSetValue(ByVal Info As ProgressBar, ByVal value As Int32)
Dim la As StDelegateProgressBarSetValue = New StDelegateProgressBarSetValue(AddressOf ProgressBarSetValue)
Info.Invoke(la, New Object() {Info, value})
Else
Info.Value = value
End If
End Sub
Private Delegate Sub StDelegateProgressBarMaximum(ByVal Info As ProgressBar, ByVal Maximum As Int32)
Private Sub SetMaximum(ByVal Info As ProgressBar, ByVal Maximum As Int32)
Dim la As StDelegateProgressBarMaximum = New StDelegateProgressBarMaximum(AddressOf SetMaximum)
Info.Invoke(la, New Object() {Info, Maximum})
Else
Info.Maximum = Maximum
End If
End Sub
Private Delegate Function StDelegateProgressBarGetValue(ByVal Info As ProgressBar)
Private Function ProgressBarGetValue(ByVal Info As ProgressBar)
Dim la As StDelegateProgressBarGetValue = New StDelegateProgressBarGetValue(AddressOf ProgressBarGetValue)
End If
Return Info.Value
End Function
Private Delegate Function StDelegateButtonGetEnabled(ByVal Info As Button)
Private Function GetEnabled(ByVal Info As Button)
Dim la As StDelegateButtonGetEnabled = New StDelegateButtonGetEnabled(AddressOf GetEnabled)
End If
Return Info.Enabled
End Function
Private Delegate Sub StDelegateButtonSetEnabled(ByVal Info As Button, ByVal enabled As Boolean)
Private Sub SetEnabled(ByVal Info As Button, ByVal Enabled As Boolean)
Dim la As StDelegateButtonSetEnabled = New StDelegateButtonSetEnabled(AddressOf SetEnabled)
Info.Invoke(la, New Object() {Info, Enabled})
Else
Info.Enabled = Enabled
End If
End Sub
Private Shared Sub GetSqlParameters(ByVal command As System.Data.SqlClient.SqlCommand)
Dim adapter As System.Data.SqlClient.SqlDataAdapter = New System.Data.SqlClient.SqlDataAdapter(" Select syscolumns.name As ParamName, systypes.name ParamType FROM sysobjects INNER JOIN syscolumns On sysobjects.id = syscolumns.id INNER JOIN systypes On syscolumns.xusertype = systypes.xusertype WHERE sysobjects.name = @ProcedureName", command.Connection.ConnectionString)
adapter.SelectCommand.Parameters.Add("@ProcedureName", System.Data.SqlDbType.NVarChar).Value = command.CommandText.Replace("dbo.", "")
Dim dt As System.Data.DataTable = New System.Data.DataTable()
adapter.Fill(dt)
Dim row As System.Data.DataRow
For Each row In dt.Rows
command.Parameters.Add(row("ParamName").ToString(), SetSqlDbType(row("ParamType").ToString()))
Next
End Sub
Private Shared Sub SetSqlParameters(ByVal command As System.Data.SqlClient.SqlCommand, ByVal row As System.Data.DataRow, ByVal columns As System.Data.DataColumnCollection)
If command Is DBNull.Value Or row Is DBNull.Value Then
Exit Sub
End If
Dim column As System.Data.DataColumn
For Each column In columns
Try
command.Parameters("@" + column.ColumnName).Value = row(column.ColumnName)
Catch
End Try
Next
End Sub
Private Shared Function SetSqlDbType(ByVal type As String) As System.Data.SqlDbType
type = type.ToLower
Select Case type
Case "bigint"
Return System.Data.SqlDbType.BigInt
Case "binary"
Return System.Data.SqlDbType.Binary
Case "bit"
Return System.Data.SqlDbType.Bit
Case "Char"
Return System.Data.SqlDbType.Char
Case "datetime"
Return System.Data.SqlDbType.DateTime
Case "Decimal"
Return System.Data.SqlDbType.Decimal
Case "numeric"
Case "float"
Return System.Data.SqlDbType.Float
Case "int"
Return System.Data.SqlDbType.Int
Case "money"
Return System.Data.SqlDbType.Money
Case "nchar"
Return System.Data.SqlDbType.NChar
Case "nvarchar"
Return System.Data.SqlDbType.NVarChar
Case "smalldatetime"
Return System.Data.SqlDbType.SmallDateTime
Case "tinyint"
Return System.Data.SqlDbType.TinyInt
Case "uniqueidentifier"
Return System.Data.SqlDbType.UniqueIdentifier
Case "varchar"
Return System.Data.SqlDbType.VarChar
Case Else
End Select
End Function
Private Sub btn_cancel_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btn_cancel.Click
If MsgBox("Вы уверены что хотите прервать загрузку?", MsgBoxStyle.YesNo, "Предупреждение") = MsgBoxResult.Yes Then
Try
Thread1.Interrupt()
Thread1 = Nothing
End Try
End If
End Sub
End Class
End Namespace
Так вот в нем есть кусок цикла
End If
XMLResult = Nothing
XMLResult = Xbyte
End If
End If
If RBytes <= 0 Then
MsgBox("RBytes <0",64,"Ошибка ввода")
Exit Sub
End If
Try
s = ""
End If
End Try
connection.Open()
End If
Try
stream.Close()
Exit Sub
End Try
connection.Close()
End If
Else
s = XMLResult
Exit While
End If
s = ""
Exit While
Else
s = XMLResult
Exit While
End If
End While
s = ""
End If
End While
Ошибку
If RBytes <= 0 Then
Exit Sub
End If
Я сам добавил! Не могу понять откуда там появляются число 0 или менее 0?
Самый большой файл весит (83 380 786 байт)
Подскажи плиз
Проблемы с кодом!
    #38890931
Фотография Shocker.Pro
Учимся использовать тэги оформления кода - FAQ
Проблемы с кодом!
    #38890947
DKasimov
Народ привет!
Есть код:
Код: vbnet
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
61.
62.
63.
64.
65.
66.
67.
68.
69.
70.
71.
72.
73.
74.
75.
76.
77.
78.
79.
80.
81.
82.
83.
84.
85.
86.
87.
88.
89.
90.
91.
92.
93.
94.
95.
96.
97.
98.
99.
100.
101.
102.
103.
104.
105.
106.
107.
108.
109.
110.
111.
112.
113.
114.
115.
116.
117.
118.
119.
120.
121.
122.
123.
124.
125.
126.
127.
128.
129.
130.
131.
132.
133.
134.
135.
136.
137.
138.
139.
140.
141.
142.
143.
144.
145.
146.
147.
148.
149.
150.
151.
152.
153.
154.
155.
156.
157.
158.
159.
160.
161.
162.
163.
164.
165.
166.
167.
168.
169.
170.
171.
172.
173.
174.
175.
176.
177.
178.
179.
180.
181.
182.
183.
184.
185.
186.
187.
188.
189.
190.
191.
192.
193.
194.
195.
196.
197.
198.
199.
200.
201.
202.
203.
204.
205.
206.
207.
208.
209.
210.
211.
212.
213.
214.
215.
216.
217.
218.
219.
220.
221.
222.
223.
224.
225.
226.
227.
228.
229.
230.
231.
232.
233.
234.
235.
236.
237.
238.
239.
240.
241.
242.
243.
244.
245.
246.
247.
248.
249.
250.
251.
252.
253.
254.
255.
256.
257.
258.
259.
260.
261.
262.
263.
264.
265.
266.
267.
268.
269.
270.
271.
272.
273.
274.
275.
276.
277.
278.
279.
280.
281.
282.
283.
284.
285.
286.
287.
288.
289.
290.
291.
292.
293.
294.
295.
296.
297.
298.
299.
300.
301.
302.
303.
304.
305.
306.
307.
308.
309.
310.
311.
312.
313.
314.
315.
316.
317.
318.
319.
320.
321.
322.
323.
324.
325.
326.
327.
328.
329.
330.
331.
332.
333.
334.
335.
336.
337.
338.
339.
340.
341.
342.
343.
344.
345.
346.
347.
348.
349.
350.
351.
352.
353.
354.
355.
356.
357.
358.
359.
360.
361.
362.
363.
364.
365.
366.
367.
368.
369.
370.
371.
372.
373.
374.
375.
376.
377.
378.
379.
380.
381.
382.
383.
384.
385.
386.
387.
388.
389.
390.
391.
392.
393.
394.
395.
396.
397.
398.
399.
400.
401.
402.
403.
404.
405.
406.
407.
408.
409.
410.
411.
412.
413.
414.
415.
416.
417.
418.
419.
420.
421.
422.
423.
424.
425.
426.
427.
428.
429.
430.
431.
432.
433.
434.
435.
436.
437.
438.
439.
440.
441.
442.
443.
444.
445.
446.
447.
448.
449.
450.
451.
452.
453.
454.
455.
456.
457.
458.
459.
460.
461.
462.
463.
464.
465.
466.
467.
468.
469.
470.
471.
472.
473.
474.
475.
476.
477.
478.
479.
480.
481.
482.
483.
484.
485.
486.
487.
488.
489.
490.
491.
492.
493.
494.
495.
496.
497.
Imports System
Imports Sherp
Namespace UserForm
        End If
    End Sub
            Exit Sub
        End If
        If dir.Exists Then
            Try
            End Try
            Try
                dir.Delete()
            End Try
        Else
            dir.Create()
        End If
        Try
                connection.Open()
            End If
            Exit Sub
        End Try
        Try
            Thread1.Start()
        Catch
        End Try
    End Sub
            connection.Open()
        End If
            Exit Sub
        End If
        Try
                Exit Sub
            End If
                Exit Sub
            End If
            Else
                Exit Sub
            End If
            Exit Sub
        End Try
        Try
                Exit Sub
            End If
                    Exit Sub
                End If
                IsUpload = True
                    connection.Open()
                End If
                            connection.Close()
                        End If
                        Continue For
                    End If
                End If
                    connection.Open()
                End If
                Try
                        End If
                        XMLResult = Nothing
                        XMLResult = Xbyte
                        End If
                        End If
                                    Try
                                            s = ""
                                        End If
                                    End Try
                                        connection.Open()
                                    End If
                                    Try
                                        stream.Close()
                                        Exit Sub
                                    End Try
                                        connection.Close()
                                    End If
                                Else
                                    s = XMLResult
                                    Exit While
                                End If
                                s = ""
                                Exit While
                            Else
                                s = XMLResult
                                Exit While
                            End If
                        End While
                            s = ""
                        End If
                    End While
                    stream.Close()
                        connection.Open()
                    End If
                    Try
                    End Try
                    stream.Close()
                End Try
            Next
            Try
            End Try
            dir.Delete()
        Finally
            Try
            End Try
            Try
                dir.Delete()
            End Try
        End Try
    End Sub
        Else
            Info.Text = Text
        End If
    End Sub
        End If
        Return Info.Text
    End Function
        Else
            Info.Text = Text
        End If
    End Sub
        End If
        Return Info.Text
    End Function
        Else
            Info.Value = value
        End If
    End Sub
        Else
        End If
    End Sub
        End If
        Return Info.Value
    End Function
        End If
        Return Info.Enabled
    End Function
        Else
        End If
    End Sub
        adapter.Fill(dt)
        Next
    End Sub
            Exit Sub
        End If
            Try
            Catch
            End Try
        Next
    End Sub
        type = type.ToLower
        Select Case type
            Case "bigint"
            Case "binary"
            Case "bit"
            Case "Char"
            Case "datetime"
            Case "Decimal"
            Case "numeric"
            Case "float"
            Case "int"
            Case "money"
            Case "nchar"
            Case "nvarchar"
            Case "tinyint"
            Case "varchar"
            Case Else
        End Select
    End Function
            Try
                Thread1.Interrupt()
                Thread1 = Nothing
            End Try
        End If
    End Sub
End Class
End Namespace
Код: vbnet
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
61.
62.
63.
64.
65.
66.
67.
68.
                        End If
                        XMLResult = Nothing
                        XMLResult = Xbyte
                        End If
                        End If
If RBytes <= 0 Then
            Exit Sub
End If
                                    Try
                                            s = ""
                                        End If
                                    End Try
                                        connection.Open()
                                    End If
                                    Try
                                        stream.Close()
                                        Exit Sub
                                    End Try
                                        connection.Close()
                                    End If
                                Else
                                    s = XMLResult
                                    Exit While
                                End If
                                s = ""
                                Exit While
                            Else
                                s = XMLResult
                                Exit While
                            End If
                        End While
Ошибку
Код: vbnet
1.
2.
3.
4.
5.
If RBytes <= 0 Then
            Exit Sub
End If
Подскажите плиз
Проблемы с кодом!
    #38890953
Фотография Axeleron
DKasimov,
Неее, столько кода, да еще на VB.NET я осилить не в состоянии. Совет: дебажить и смотреть где этот 0 как раз и появляется. Как найдете, тогда приходите и спросите почему оно стало 0 там, если сами не разберетесь.
Проблемы с кодом!
    #38890976
DKasimov
Axeleron,
Код там вообще адский))) Ему лет уже)))
Я уже про него забыл, а тут нет)) сервис лег и решили поднять старый механизм загрузки из архива))
Ну похоже нашел проблему! Все это дело берет кусок кода весом максимум 2 метра, причем с указанием куска откуда и докуда брать))
вот этот кусок может быть больше 2-х метров и поэтому просто непонятно что делать)))
Сейчас проверю и посмотрим
Проблемы с кодом!
    #38890985
Фотография Axeleron
DKasimov,
Пилите, Шура, пилите!
