Подписание XML файлов с помощью x509 с использованием контроллов OFD & SFD
#38952623
Ссылка:
Здравствуйте, уважаемые форумчане!
Есть такой код:
1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79. 80. 81. 82. 83. 84. 85. 86. 87. 88. 89. 90. 91. 92. 93. 94. 95. 96. 97. 98. 99. 100. 101. 102. 103. 104. 105. 106. 107. 108. 109. 110. 111. 112. 113. 114. 115. 116. 117. 118. 119. 120.
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using System.Security.Cryptography;
using System.Security.Cryptography.X509Certificates;
namespace WindowsFormsApplication1
public partial class CertificateForm : Form
public CertificateForm()
InitializeComponent();
//private void CertificateForm_Load(object sender, EventArgs e)
private void SignToolStripButton_Click(object sender, EventArgs e)
try
byte[] plainData, signatureData;
plainData = Encoding.UTF8.GetBytes(PlainRichTextBox.Text);
X509Store store = new X509Store(StoreLocation.CurrentUser);
store.Open(OpenFlags.ReadOnly | OpenFlags.OpenExistingOnly);
X509Certificate2Collection certificates = store.Certificates;
X509Certificate2Collection foundCertificates = certificates.Find(X509FindType.FindByTimeValid, DateTime.Now, true);
X509Certificate2Collection selectedCertificates = X509Certificate2UI.SelectFromCollection(foundCertificates,
"Select a Certificate.", "Select a Certificate from the following list to get information on that certificate", X509SelectionFlag.SingleSelection);
if (selectedCertificates.Count > 0)
X509Certificate2 certificate = selectedCertificates[0];
if (certificate.HasPrivateKey)
RSACryptoServiceProvider rsaEncryptor = (RSACryptoServiceProvider)certificate.PrivateKey;
signatureData = rsaEncryptor.SignData(plainData, new SHA1CryptoServiceProvider());
CipherRichTextBox.Text = Convert.ToBase64String(signatureData);
else
MessageBox.Show("the selected certificate does not contain a Private Key to use in signing data",
"No Private Key Available", MessageBoxButtons.OK, MessageBoxIcon.Exclamation);
catch (CryptographicException ex)
MessageBox.Show(ex.Message, ex.GetType().ToString(),
MessageBoxButtons.OK, MessageBoxIcon.Error);
catch (Exception ex)
private void VerifyToolStripButton_Click(object sender, EventArgs e)
try
signatureData = Convert.FromBase64String(CipherRichTextBox.Text);
RSACryptoServiceProvider rsaEncryptor = (RSACryptoServiceProvider)certificate.PublicKey.Key;
if (rsaEncryptor.VerifyData(plainData, new SHA1CryptoServiceProvider(), signatureData))
MessageBox.Show("Your signature has been verified successfully.", "Success",
MessageBoxButtons.OK, MessageBoxIcon.Information);
else
MessageBox.Show("Your Data cannot be verified against the Signature.", "Failure",
Он работает, но так не пойдет. Нужно не вручную текст вбивать или вставлять в RichTextBox,а так сделать, чтобы можно было взять много файлов (от 500 вроде) из одной папки, подписать их с ЭЦП и переложить в другую.
Думал с помощью Openfiledialog & SaveFileDialog делать, но, кажется, что так неправильно... Но пока что хотелось бы, чтобы хоть так работало.
1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79. 80. 81. 82. 83. 84. 85. 86. 87. 88. 89. 90. 91. 92. 93. 94. 95. 96. 97. 98. 99. 100. 101. 102. 103. 104. 105. 106. 107. 108. 109. 110. 111. 112. 113. 114. 115. 116. 117. 118. 119. 120. 121. 122. 123. 124. 125. 126. 127. 128. 129. 130. 131.
using System;
using System.Data;
using System.Linq;
using System.Text;
try
//byte[] plainData, signatureData;
//plainData = Encoding.UTF8.GetBytes(PlainRichTextBox.Text);//как вот без этой плейндейты и ричтекстбокса обойтись?
OpenFileDialog ofd = new OpenFileDialog();
ofd.Multiselect = true;//это что-то тоже не работает
ofd.Filter = "XML(*.xml)|*.xml|All files (*.*)| *.*";
if (ofd.ShowDialog() == DialogResult.OK)
else
try
else
SaveFileDialog sfd = new SaveFileDialog();
//sfd.SupportMultiDottedExtensions = true;
sfd.Filter = "XML (*.xml)|*.xml";
if (sfd.ShowDialog() == DialogResult.OK)
Тут подскажите,пожалуйста, как сделать так, если это возможно , чтобы без ричбоксов: открылся диалог, выбрали файлы, они подписались, проверились, открылся другой диалог, их сохранили.
Заранее большое спасибо!
