Форумы / WinForms, .Net Framework [игнор отключен] [закрыт для гостей] / ClickOnce ошибка
ClickOnce ошибка
    #38996829
CoderID
Здравствуйте,
после конвертации проекта, созданного в Visual Studio 2008, в проект для Visual Studio 2013, перестал работать ClickOnce инсталлятор.
В чем может быть дело?
При запуске инстллятора получаю такую ошибку
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
61.
62.
63.
64.
65.
66.
67.
68.
69.
70.
71.
72.
73.
74.
75.
76.
77.
78.
79.
80.
81.
82.
83.
84.
85.
86.
87.
88.
89.
90.
91.
92.
93.
94.
95.
96.
97.
98.
99.
100.
101.
102.
103.
104.
PLATFORM VERSION INFO
        Windows             : 6.1.7601.65536 (Win32NT)
        Common Language Runtime     : 4.0.30319.18408
        System.Deployment.dll       : 4.0.30319.18408 built by: FX451RTMGREL
        clr.dll             : 4.0.30319.18408 built by: FX451RTMGREL
        dfdll.dll           : 4.0.30319.18408 built by: FX451RTMGREL
        dfshim.dll          : 4.0.41209.0 (Main.041209-0000)
    SOURCES
    file:///C:/Documents%20and%20Settings/<username>/Start%20Menu/Programs/<programname>/<programname>.appref-ms%7C
        Deployment url          : file://MyServer/d/My_Setup/MyApp.application
        Deployment Provider url     : file://MyServer/d/My_Setup/MyApp.application
        Application url         : ile://MyServer/d/My_Setup/Application%20Files/MyApp_1_0_0_711/MyApp.exe.manifest
    IDENTITIES
        Deployment Identity     : MyApp.application, Version=1.0.0.711, Culture=neutral, PublicKeyToken=cdfbb15e6196321d, processorArchitecture=msil
        Application Identity        : MyApp.exe, Version=1.0.0.711, Culture=neutral, PublicKeyToken=cdfbb15e6196321d, processorArchitecture=msil, type=win32
    APPLICATION SUMMARY
        * Installable application.
    ERROR SUMMARY
        Below is a summary of the errors, details of these errors are listed later in the log.
        * Activation of \\MyServer\d\My_Setup\MyApp.application resulted in exception. Following failure messages were detected:
            + Value does not fall within the expected range.
    COMPONENT STORE TRANSACTION FAILURE SUMMARY
        No transaction error was detected.
    WARNINGS
        There were no warnings during this operation.
    OPERATION PROGRESS STATUS
        * [01/07/2015 11:34:15] : Activation of \\MyServer\d\My_Setup\MyApp.application has started.
        * [01/07/2015 11:34:15] : Processing of deployment manifest has successfully completed.
        * [01/07/2015 11:34:15] : Installation of the application has started.
        * [01/07/2015 11:34:16] : Processing of application manifest has successfully completed.
        * [01/07/2015 11:34:19] : Found compatible runtime version 2.0.50727.
        * [01/07/2015 11:34:19] : Detecting dependent assembly Sentinel.v3.5Client, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a, processorArchitecture=msil using Sentinel.v3.5Client, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a, processorArchitecture=msil.
        * [01/07/2015 11:34:19] : Detecting dependent assembly System.Data.Entity, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089, processorArchitecture=msil using System.Data.Entity, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089, processorArchitecture=msil.
        * [01/07/2015 11:34:19] : Detecting dependent assembly WindowsBase, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35, processorArchitecture=msil using WindowsBase, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35, processorArchitecture=msil.
        * [01/07/2015 11:34:19] : Detecting dependent assembly CrystalDecisions.ReportAppServer.XmlSerialize, Version=10.5.3700.0, Culture=neutral, PublicKeyToken=692FBEA5521E1304, processorArchitecture=msil using CrystalDecisions.ReportAppServer.XmlSerialize, Version=10.5.3700.0, Culture=neutral, PublicKeyToken=692fbea5521e1304, processorArchitecture=msil.
        * [01/07/2015 11:34:19] : Detecting dependent assembly CrystalDecisions.ReportAppServer.CommonControls, Version=10.5.3700.0, Culture=neutral, PublicKeyToken=692FBEA5521E1304, processorArchitecture=msil using CrystalDecisions.ReportAppServer.CommonControls, Version=10.5.3700.0, Culture=neutral, PublicKeyToken=692fbea5521e1304, processorArchitecture=msil.
        * [01/07/2015 11:34:19] : Detecting dependent assembly CrystalDecisions.Windows.Forms, Version=13.0.2000.0, Culture=neutral, PublicKeyToken=692FBEA5521E1304, processorArchitecture=msil using CrystalDecisions.Windows.Forms, Version=13.0.2000.0, Culture=neutral, PublicKeyToken=692fbea5521e1304, processorArchitecture=msil.
        * [01/07/2015 11:34:19] : Detecting dependent assembly CrystalDecisions.ReportAppServer.Controllers, Version=10.5.3700.0, Culture=neutral, PublicKeyToken=692FBEA5521E1304, processorArchitecture=msil using CrystalDecisions.ReportAppServer.Controllers, Version=10.5.3700.0, Culture=neutral, PublicKeyToken=692fbea5521e1304, processorArchitecture=msil.
        * [01/07/2015 11:34:19] : Detecting dependent assembly CrystalDecisions.ReportAppServer.DataSetConversion, Version=10.5.3700.0, Culture=neutral, PublicKeyToken=692FBEA5521E1304, processorArchitecture=msil using CrystalDecisions.ReportAppServer.DataSetConversion, Version=10.5.3700.0, Culture=neutral, PublicKeyToken=692fbea5521e1304, processorArchitecture=msil.
        * [01/07/2015 11:34:19] : Detecting dependent assembly CrystalDecisions.Shared, Version=13.0.2000.0, Culture=neutral, PublicKeyToken=692FBEA5521E1304, processorArchitecture=msil using CrystalDecisions.Shared, Version=13.0.2000.0, Culture=neutral, PublicKeyToken=692fbea5521e1304, processorArchitecture=msil.
        * [01/07/2015 11:34:19] : Detecting dependent assembly System.Core, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089, processorArchitecture=msil using System.Core, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089, processorArchitecture=msil.
        * [01/07/2015 11:34:19] : Detecting dependent assembly CrystalDecisions.ReportAppServer.CommonObjectModel, Version=10.5.3700.0, Culture=neutral, PublicKeyToken=692FBEA5521E1304, processorArchitecture=msil using CrystalDecisions.ReportAppServer.CommonObjectModel, Version=10.5.3700.0, Culture=neutral, PublicKeyToken=692fbea5521e1304, processorArchitecture=msil.
        * [01/07/2015 11:34:19] : Detecting dependent assembly CrystalDecisions.ReportSource, Version=13.0.2000.0, Culture=neutral, PublicKeyToken=692FBEA5521E1304, processorArchitecture=msil using CrystalDecisions.ReportSource, Version=13.0.2000.0, Culture=neutral, PublicKeyToken=692fbea5521e1304, processorArchitecture=msil.
        * [01/07/2015 11:34:19] : Detecting dependent assembly CrystalDecisions.ReportAppServer.DataDefModel, Version=10.5.3700.0, Culture=neutral, PublicKeyToken=692FBEA5521E1304, processorArchitecture=msil using CrystalDecisions.ReportAppServer.DataDefModel, Version=10.5.3700.0, Culture=neutral, PublicKeyToken=692fbea5521e1304, processorArchitecture=msil.
        * [01/07/2015 11:34:19] : Detecting dependent assembly CrystalDecisions.ReportAppServer.ObjectFactory, Version=10.5.3700.0, Culture=neutral, PublicKeyToken=692FBEA5521E1304, processorArchitecture=msil using CrystalDecisions.ReportAppServer.ObjectFactory, Version=10.5.3700.0, Culture=neutral, PublicKeyToken=692fbea5521e1304, processorArchitecture=msil.
        * [01/07/2015 11:34:19] : Detecting dependent assembly CrystalDecisions.ReportAppServer.ReportDefModel, Version=10.5.3700.0, Culture=neutral, PublicKeyToken=692FBEA5521E1304, processorArchitecture=msil using CrystalDecisions.ReportAppServer.ReportDefModel, Version=10.5.3700.0, Culture=neutral, PublicKeyToken=692fbea5521e1304, processorArchitecture=msil.
        * [01/07/2015 11:34:19] : Detecting dependent assembly CrystalDecisions.CrystalReports.Engine, Version=13.0.2000.0, Culture=neutral, PublicKeyToken=692FBEA5521E1304, processorArchitecture=msil using CrystalDecisions.CrystalReports.Engine, Version=13.0.2000.0, Culture=neutral, PublicKeyToken=692fbea5521e1304, processorArchitecture=msil.
        * [01/07/2015 11:34:19] : Detecting dependent assembly CrystalDecisions.ReportAppServer.CommLayer, Version=10.5.3700.0, Culture=neutral, PublicKeyToken=692FBEA5521E1304, processorArchitecture=msil using CrystalDecisions.ReportAppServer.CommLayer, Version=10.5.3700.0, Culture=neutral, PublicKeyToken=692fbea5521e1304, processorArchitecture=msil.
        * [01/07/2015 11:34:19] : Detecting dependent assembly CrystalDecisions.ReportAppServer.ClientDoc, Version=10.5.3700.0, Culture=neutral, PublicKeyToken=692FBEA5521E1304, processorArchitecture=msil using CrystalDecisions.ReportAppServer.ClientDoc, Version=10.5.3700.0, Culture=neutral, PublicKeyToken=692fbea5521e1304, processorArchitecture=msil.
        * [01/07/2015 11:34:19] : Request of trust and detection of platform is complete.
        * [01/07/2015 11:34:47] : Downloading of subscription dependencies is complete.
        * [01/07/2015 11:34:47] : Commit of the downloaded application has started.
        * [01/07/2015 11:34:53] : Installation of application has successfully completed.
    ERROR DETAILS
        Following errors were detected during this operation.
        * [01/07/2015 11:34:53] System.ArgumentException
            - Value does not fall within the expected range.
            - Source: System.Deployment
            - Stack trace:
                at System.Deployment.Application.NativeMethods.CorLaunchApplication(UInt32 hostType, String applicationFullName, Int32 manifestPathsCount, String[] manifestPaths, Int32 activationDataCount, String[] activationData, PROCESS_INFORMATION processInformation)
                at System.Deployment.Application.ComponentStore.ActivateApplication(DefinitionAppId appId, String activationParameter, Boolean useActivationParameter)
                at System.Deployment.Application.SubscriptionStore.ActivateApplication(DefinitionAppId appId, String activationParameter, Boolean useActivationParameter)
                at System.Deployment.Application.ApplicationActivator.Activate(DefinitionAppId appId, AssemblyManifest appManifest, String activationParameter, Boolean useActivationParameter)
                at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
                at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
    COMPONENT STORE TRANSACTION DETAILS
        * Transaction at [01/07/2015 11:34:53]
            + System.Deployment.Internal.Isolation.StoreOperationStageComponent
                - Status: Installed
                - HRESULT: 0x0
                - Manifest: DHMC5ZJ6.ABJ.application
            + System.Deployment.Internal.Isolation.StoreOperationSetDeploymentMetadata
                - Status: Set
                - HRESULT: 0x0
                - Status: Installed
                - HRESULT: 0x0
                - Manifest: MyApp.exe.manifest
            + System.Deployment.Internal.Isolation.StoreOperationStageComponentFile
                - Status: Installed
                - HRESULT: 0x0
                - File: Purchase\Reports\rpt_PurchaseOrderFooterLat.rpt
                - Status: Installed
                - HRESULT: 0x0
                - File: Resourses\Printer.png
                - Status: Installed
                - HRESULT: 0x0
                - File: Resourses\stock_mail-receive1.png
