Как вывести данный с фото в форме на C# SQL
добавить данных на базу данных а как вывести эти данных с фото на форме не знаю.... C# SQL try { byte[] img = null; FileStream fs = new FileStream(imgLoc, FileMode.Open, FileAccess.Read); BinaryReader br = new BinaryReader(fs); img = br.ReadBytes((int)fs.Length); //string sql = "Insert into Logtable (Nom, Nasab, Sanai_Tavallud, Joyi_Zist, Username, Password,Surat) values('" + textBox1.Text + "','" + textBox2.Text + "','" + dateTimePickerDate.Value.ToShortTimeString() + "','" + textBox4.Text + "','" + textBox5.Text + "','" + textBox6.Text + "',@img)"; SqlCommand cmd = new SqlCommand("Insert into TBaqaydgir(NomuNasab,SanaiTavallud,JoyiZist,Username,Password,Photo,INN_Passport)values(@NomuNasab,@SanaiTavallud,@JoyiZist,@Username,@Password,@Photo,@INN_Passport)", con); cmd.Parameters.Add(new SqlParameter("@NomuNasab", SqlDbType.NVarChar, 50)); cmd.Parameters["@NomuNasab"].Value = textBox1.Text; cmd.Parameters.Add(new SqlParameter("@SanaiTavallud", SqlDbType.Date)); cmd.Parameters["@SanaiTavallud"].Value = dateTimePickerDate.Value.ToShortDateString(); cmd.Parameters.Add(new SqlParameter("@JoyiZist", SqlDbType.NVarChar, 100)); cmd.Parameters["@JoyiZist"].Value = textBox4.Text; cmd.Parameters.Add(new SqlParameter("@Username", SqlDbType.NVarChar, 10)); cmd.Parameters["@Username"].Value = textBox5.Text; cmd.Parameters.Add(new SqlParameter("@Password", SqlDbType.NVarChar, 10)); cmd.Parameters["@Password"].Value = textBox6.Text; cmd.Parameters.Add(new SqlParameter("@INN_Passport", SqlDbType.NVarChar, 20)); cmd.Parameters["@INN_Passport"].Value = textBox6.Text; cmd.Parameters.Add(new SqlParameter("@Photo", SqlDbType.Image)); cmd.Parameters["@Photo"].Value = img; Metod_SelectFrmRegistration(); con.Open(); cmd.ExecuteNonQuery(); con.Close(); DialogResult = DialogResult.OK; textBox1.Text = ""; textBox2.Text = ""; dateTimePickerDate.Text = ""; textBox4.Text = ""; textBox5.Text = ""; textBox6.Text = ""; picEmp.Image = Resources.logonPictureBox; button1.Enabled = false; } catch (Exception x) { } ... |
| 24.01.2017, 21:13 |
| 24.01.2017, 22:29 |
Код: c# 1. 2. 3. 4. 5. ... |
| 25.01.2017, 10:38 |
Cat2, спасибо за помощь.... ... |
| 25.01.2017, 13:26 |
Кстати KingHacker Код: c# 1. 2. эквивалентно Код: c# 1. ... |
| 25.01.2017, 18:54 |
start [/forum/topic.php?fid=20&gotonew=1&tid=1400096]: |
154ms |
| others: | 229ms |
| total: | 447ms |
