Подскажите, что значит ошибка
Добрый час! Можете подсказать, что означает ошибка и как ее исправить? Запускаю программу. See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.BadImageFormatException: Could not load file or assembly 'rubotNet, Version=1.0.9.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. An attempt was made to load a program with an incorrect format. File name: 'rubotNet, Version=1.0.9.0, Culture=neutral, PublicKeyToken=null' at ______________(Object , Object , Object ) at System.Windows.Forms.Form.OnLoad(EventArgs e) at System.Windows.Forms.Form.OnCreateControl() at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.WmShowWindow(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.Form.WmShowWindow(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) WRN: Assembly binding logging is turned OFF. To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Note: There is some performance penalty associated with assembly bind failure logging. To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog]. ************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.7.3062.0 built by: NET472REL1 CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll --------------------------------------— RuBotTools Assembly Version: 6.6.8.0 Win32 Version: 6.6.8.0 CodeBase: file:///C:/Programs/RuBotAdmin/RuBots/RuBot_00002/RuBotTools.exe --------------------------------------— System Assembly Version: 4.0.0.0 Win32 Version: 4.7.3062.0 built by: NET472REL1 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__.. --------------------------------------— System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.7.3062.0 built by: NET472REL1 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/.. --------------------------------------— System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.7.3062.0 built by: NET472REL1 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.. --------------------------------------— System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.7.3062.0 built by: NET472REL1 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/.. --------------------------------------— System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.7.3081.0 built by: NET472REL1 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0... --------------------------------------— System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.7.3062.0 built by: NET472REL1 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.. --------------------------------------— ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box. ... |
| 20.01.2019, 18:46 |
kadastr55, не хватает сборки rubotNet, обратитесь к разработчикам RuBotAdmin ... |
| 20.01.2019, 19:02 |
rubotadmin это просто программа, которая управляет Основной программой, включает ее мышкой и клавой. ... |
| 20.01.2019, 19:12 |
kadastr55, так запустите Основную программу напрямую, а не через rubotadmin ... |
| 20.01.2019, 19:32 |
Дмитрий Мух, у меня автоматизация. Все работало хорошо до обновления основной программы. ... |
| 20.01.2019, 19:41 |
Дмитрий Мухkadastr55, не хватает сборки rubotNet, обратитесь к разработчикам RuBotAdmin Не хватает этой сборки нужной разрядности. BadImageFormatException говорит именно об этом, он вылетает при попытке загрузить сборку или нативную dll, когда не совпадают разрядность процесса и загружаемой сборки/dll (в x86 грузят х64, или наоборот). ... |
| 21.01.2019, 03:04 |
start [/forum/topic.php?fid=20&gotonew=1&tid=1399107]: |
80ms |
42ms |
| others: | 246ms |
| total: | 413ms |
