Add Service Reference
В студии делаю Add Service Reference... указываю http://smev-mvf.test.gosuslugi.ru:7777/gateway/services/SID0004656?wsdl Получаю следующие варнинги. Подскажите в какую сторону копать? Аналогично если делать через svcutil.exe Но svcutil.exe /t:metadata http://smev-mvf.test.gosuslugi.ru:7777/gateway/services/SID0004656?wsdl успешно выкачивает все xsd и т.д. Warning 1 Custom tool warning: Cannot import wsdl:portType Detail: An exception was thrown while running a WSDL import extension: System.ServiceModel.Description.XmlSerializerMessageContractImporter Error: There was a problem loading the XSD documents provided: a reference to a schema element with name 'CRACheckRequest' and namespace 'http://smev.gosuslugi.ru/rev111111' could not be resolved because the element definition could not be found in the schema for targetNamespace 'http://smev.gosuslugi.ru/rev111111'. Please check the XSD documents provided and try again. XPath to Error Source: //wsdl:definitions[@targetNamespace='http://mvd.ru/services/cra']/wsdl:portType[@name='CRAService'] c:\users\infinits\documents\visual studio 2013\Projects\Test\ConsoleApplication4\ConsoleApplication4\Service References\ServiceReference1\Reference.svcmap 1 1 ConsoleApplication4 Warning 2 Custom tool warning: Cannot import wsdl:binding Detail: There was an error importing a wsdl:portType that the wsdl:binding is dependent on. XPath to wsdl:portType: //wsdl:definitions[@targetNamespace='http://mvd.ru/services/cra']/wsdl:portType[@name='CRAService'] XPath to Error Source: //wsdl:definitions[@targetNamespace='http://mvd.ru/services/cra']/wsdl:binding[@name='CRAServicePortBinding'] c:\users\infinits\documents\visual studio 2013\Projects\Test\ConsoleApplication4\ConsoleApplication4\Service References\ServiceReference1\Reference.svcmap 1 1 ConsoleApplication4 Warning 3 Custom tool warning: Cannot import wsdl:port Detail: There was an error importing a wsdl:binding that the wsdl:port is dependent on. XPath to wsdl:binding: //wsdl:definitions[@targetNamespace='http://mvd.ru/services/cra']/wsdl:binding[@name='CRAServicePortBinding'] XPath to Error Source: //wsdl:definitions[@targetNamespace='http://mvd.ru/services/cra']/wsdl:service[@name='CRAService']/wsdl:port[@name='CRAServicePort'] c:\users\infinits\documents\visual studio 2013\Projects\Test\ConsoleApplication4\ConsoleApplication4\Service References\ServiceReference1\Reference.svcmap 1 1 ConsoleApplication4 Warning 4 Custom tool warning: Cannot import wsdl:portType Detail: An exception was thrown while running a WSDL import extension: System.ServiceModel.Description.XmlSerializerMessageContractImporter Error: There was a problem loading the XSD documents provided: a reference to a schema element with name 'CRACheckRequest' and namespace 'http://smev.gosuslugi.ru/rev111111' could not be resolved because the element definition could not be found in the schema for targetNamespace 'http://smev.gosuslugi.ru/rev111111'. Please check the XSD documents provided and try again. XPath to Error Source: //wsdl:definitions[@targetNamespace='http://www.red-soft.biz/ncore/dx/1.1/smev24/ws']/wsdl:portType[@name='NCoreDxSmev24Port'] c:\users\infinits\documents\visual studio 2013\Projects\Test\ConsoleApplication4\ConsoleApplication4\Service References\ServiceReference1\Reference.svcmap 1 1 ConsoleApplication4 Warning 5 Custom tool warning: Cannot import wsdl:binding Detail: There was an error importing a wsdl:portType that the wsdl:binding is dependent on. XPath to wsdl:portType: //wsdl:definitions[@targetNamespace='http://www.red-soft.biz/ncore/dx/1.1/smev24/ws']/wsdl:portType[@name='NCoreDxSmev24Port'] XPath to Error Source: //wsdl:definitions[@targetNamespace='http://www.red-soft.biz/ncore/dx/1.1/smev24/ws']/wsdl:binding[@name='NCoreDxSmev24Binding'] c:\users\infinits\documents\visual studio 2013\Projects\Test\ConsoleApplication4\ConsoleApplication4\Service References\ServiceReference1\Reference.svcmap 1 1 ConsoleApplication4 Warning 6 Custom tool warning: Cannot import wsdl:port Detail: There was an error importing a wsdl:binding that the wsdl:port is dependent on. XPath to wsdl:binding: //wsdl:definitions[@targetNamespace='http://www.red-soft.biz/ncore/dx/1.1/smev24/ws']/wsdl:binding[@name='NCoreDxSmev24Binding'] XPath to Error Source: //wsdl:definitions[@targetNamespace='http://www.red-soft.biz/ncore/dx/1.1/smev24/ws']/wsdl:service[@name='NCoreDxSmev24Service']/wsdl:port[@name='NCoreDxSmev24Port'] c:\users\infinits\documents\visual studio 2013\Projects\Test\ConsoleApplication4\ConsoleApplication4\Service References\ServiceReference1\Reference.svcmap 1 1 ConsoleApplication4 Error 7 Custom tool error: Failed to generate code for the service reference 'ServiceReference1'. Please check other error and warning messages for details. c:\users\infinits\documents\visual studio 2013\Projects\Test\ConsoleApplication4\ConsoleApplication4\Service References\ServiceReference1\Reference.svcmap 1 1 ConsoleApplication4 ... |
| 18.01.2017, 12:33:53 |
INFINITsВ студии делаю Add Service Reference... указываю http://smev-mvf.test.gosuslugi.ru:7777/gateway/services/SID0004656?wsdl Получаю следующие варнинги. Подскажите в какую сторону копать? В сторону разработчиков СМЭВ, а точнее разработчиков сервиса с namespace http://mvd.ru/services/cra. Собственно проблема понятная. В вашем WSDL объявлено, что структура сервиса CRAService выглядит вот так (я выбросил лишнее): Код: xml 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. Т.е. парсер WSDL пытается разобрать структуру порта <portType name="CRAService">. Этот порт включает в себя 2 операции getGunsInfo и checkStatus. С первой, как ни странно всё в порядке, а вот со второй - сложности. Для обеих операций используются по 2 сообщения (на вход и выход: CRAGetRequestInput/CRAGetRequestOutput, CRACheckRequestInput/CRACheckRequestOutput) каждая имеет структуру, которая должна быть описана в пространстве имен Код: xml 1. Смотрим откуда можно взять схему для этого пространства имен. Ссылка ровно 1: Код: xml 1. Качаем эту XSD, и обнаруживаем там только Код: xml 1. 2. 3. 4. 5. 6. Т.е. для первой операции структуры есть, а для второй - нет. Почему так - ответить могут только разработчики. Я могу только предложить следующее: т.к. в описании самого биндинга Код: xml 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. Объявлена только 1 операция, то вторая просто пока не готова. Поэтому попробуйте скачать все файлы wsdl и xsd, а затем удалите из wsdl операцию "checkStatus" из описания port type описание сообщений CRACheckRequestInput и CRACheckRequestOutput И попробуйте сгенерировать код из полученных файлов. У меня прошло без ошибок в генерации контрактов, но споткнулось на определении политик безопасности. И да, тип GunsListType, тоже, похоже, не удастся просто так импортировать - (он, похоже, используется во второй операции, но он не совместим с DataContractSerializer, судя по всему). ... |
| 18.01.2017, 14:30:22 |
Огромное спасибо. Будем писать разработчикам и попробую сделать как Вы сказали. ... |
| 19.01.2017, 01:35:13 |
МихаилРУ меня прошло без ошибок в генерации контрактов, но споткнулось на определении политик безопасности. Как оказалось существует еще один сервис, в котором они вырезали не доделанные методы. http://smev-mvf.test.gosuslugi.ru:7777/gateway/services/SID0004657?wsdl Но как я понимаю, как раз это и есть проблема с политиками. Как я понимаю, отчасти на это можно забить а все привязки описать самому в app.config и все будет гуд? Или все же можно, как-то настроить чтобы студия все сгенерила сама? Warning 1 Custom tool warning: Cannot import wsdl: binding Detail: An exception was thrown in a call to a policy import extension. Extension: System.ServiceModel.Channels.SecurityBindingElementImporter Error: An unsupported security policy assertion was detected during the security policy import: <sp:AsymmetricBinding xmlns:sp=" http://docs.oasis-open.org/ws-sx/ws-securitypolicy/200702"> <wsp:Policy xmlns:wsp=" http://www.w3.org/ns/ws-policy"> <sp:InitiatorToken> <wsp:Policy> <sp:X509Token sp:IncludeToken=" http://docs.oasis-open.org/ws-sx/ws-securitypolicy/200702/IncludeToken/Always"> <wsp:Policy> <sp:RequireThumbprintReference /> </wsp:Policy> </sp:X509Token> </wsp:Policy> </sp:InitiatorToken> <sp:RecipientToken> <wsp:Policy> <sp:X509Token sp:IncludeToken=" http://docs.oasis-open.org/ws-sx/ws-securitypolicy/200702/IncludeToken/Always"> <wsp:Policy> ... XPath to Error Source: //wsdl: definitions[@targetNamespace='http://www.red-soft.biz/ncore/dx/1.1/smev25/ws']/wsdl: binding[@name='NCoreDxSmev25Binding'] Warning 2 Custom tool warning: Cannot import wsdl: port Detail: There was an error importing a wsdl: binding that the wsdl:port is dependent on. XPath to wsdl: binding: //wsdl:definitions[@targetNamespace='http://www.red-soft.biz/ncore/dx/1.1/smev25/ws']/wsdl: binding[@name='NCoreDxSmev25Binding'] XPath to Error Source: //wsdl: definitions[@targetNamespace='http://www.red-soft.biz/ncore/dx/1.1/smev25/ws']/wsdl: service[@name='NCoreDxSmev25Service']/wsdl:port[@name='NCoreDxSmev25Port'] ... |
| 19.01.2017, 09:05:19 |
Как я понимаю basicHttpBinding не о собо совместим algorithmSuite="BasicGost", видимо надо делать какой-то custombinding? Или же все вынести в код где algorithmSuite будет определяться сторроней библиотекой? Код: c# 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. ... |
| 19.01.2017, 10:41:00 |
INFINITs, По поводу шифрования ничего сказать не могу, не занимался. Знаю только, что вся криптография (включая ассиметричную и сертификаты в том числе), построена на базе семейства алгоритмов GOST. В это форуме коллеги уже обсуждали как его добавить к WCF. Если не ошибаюсь, при этом использовались криптомодули от кого-то из сертифицированных поставщиков. Увы, это всё чем могу помочь. Попробуйте поднять старые темы. ... |
| 19.01.2017, 17:44:16 |
МихаилРЗнаю только, что вся криптография (включая ассиметричную и сертификаты в том числе), построена на базе семейства алгоритмов GOST. Имеется в виду криптография для СМЭВ и прочих госсервисов. ... |
| 19.01.2017, 18:09:24 |
Для шифрования придется использовать сертифицированных поставщиков и соответственно сертификаты от них (CryptoPro, VipNet и т.п.) По мне так наиболее удобен CryptoPro, т.к. у него есть библиотеки для NET и Java и не надо на низком уровне программировать. ... |
| 06.02.2017, 18:10:08 |
start [/forum/topic.php?fid=19&gotonew=1&tid=1396738]: |
49ms |
| others: | 193ms |
| total: | 307ms |
