powered by simpleCommunicator - 2.0.51     © 2025 Programmizd 02
Форумы / WCF, Web Services, Remoting [игнор отключен] [закрыт для гостей] / mono wcf openssl (сложности с transport)
    #39455758
Bonus85
Ubuntu 16.04
Mono / .Net 4.5
Код: powershell
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
$ echo '100001' >serial
$ touch certindex.txt
$ mkdir certs
$ openssl req -config yourdomain-CA.conf -new -x509 -days 3650 -keyout yourdomain-CA.key -passout pass:qwerty -out yourdomain-CA.pem
$ openssl req -config yourdomain.server.conf -days 3650 -newkey rsa:4096 -keyout yourdomain.server.key -out yourdomain.server.req
$ openssl ca -batch -config openssl.cnf -cert yourdomain-CA.pem -keyfile yourdomain-CA.key -key qwerty -extfile yourdomain.server.conf -extensions server_exts -out yourdomain.server.pem -in yourdomain.server.req
$ openssl pkcs12 -export -passout pass:qwerty -out yourdomain.server.pfx -inkey yourdomain.server.key -in yourdomain.server.pem
$ openssl x509 -in yourdomain.server.pem -text > yourdomain.server.cert
$ openssl pkcs12 -export -out yourdomain.server.p12 -inkey yourdomain.server.key -in yourdomain.server.pem
$ certmgr --add -c -p qwerty Trust yourdomain.server.pfx
$ httpcfg -add -port 2787 -p12 yourdomain.server.p12 -pwd qwerty
Код: c#
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
[ServiceContract]
public interface IJsonSecurityTokenService
	[OperationContract]
	[WebGet(UriTemplate = "get?message={message}", BodyStyle = WebMessageBodyStyle.Bare, RequestFormat = WebMessageFormat.Json, ResponseFormat = WebMessageFormat.Json)]
	string Get (string message);
[ServiceBehavior (InstanceContextMode = InstanceContextMode.PerCall, ConcurrencyMode = ConcurrencyMode.Single)]
[AspNetCompatibilityRequirements (RequirementsMode = AspNetCompatibilityRequirementsMode.Allowed)]
public class SecurityTokenService : IJsonSecurityTokenService
	public string Get (string message)
		return message;
Код: c#
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
61.
62.
63.
64.
65.
66.
67.
68.
69.
public class SecurityTokenServiceHost : ServiceHost
	public WebHttpBinding binding { get; private set; }
	public SecurityTokenServiceHost (Uri[] baseAddresses)
		: base (typeof(SecurityTokenService), baseAddresses)
		binding = new WebHttpBinding (WebHttpSecurityMode.Transport);
		binding.Security.Transport.ClientCredentialType = HttpClientCredentialType.None;
	protected override void ApplyConfiguration()
		this.Credentials.ServiceCertificate.SetCertificate(StoreLocation.CurrentUser,StoreName.Root, X509FindType.FindByThumbprint, "5CD73A7EEEDD05CB600BFBB6D85D5B6D3DB94E76");
		base.ApplyConfiguration ();
	protected override void OnOpening()
		var contract = ContractDescription.GetContract (typeof(IJsonSecurityTokenService));
		var endpointAddress = new EndpointAddress (new Uri (this.BaseAddresses [0], "security/web"));
		this.AddServiceEndpoint (new ServiceEndpoint (contract, binding, endpointAddress));
		var webHttpBehavior = new WebHttpBehavior();
		this.Description.Endpoints[0].Behaviors.Add(webHttpBehavior);
		var metadataBehavior = new ServiceMetadataBehavior ();
		metadataBehavior.HttpsGetEnabled = true;
		this.Description.Behaviors.Add (metadataBehavior);
		var debugBehavior = this.Description.Behaviors.Find<ServiceDebugBehavior> ();
		debugBehavior.IncludeExceptionDetailInFaults = true;
		base.OnOpening();
public static void Main (string[] args)
	var baseUri = new Uri ("https://" + Environment.MachineName + ":2787");
	var host = new SecurityTokenServiceHost (new []{ baseUri });
	host.Open ();
	try
		HttpWebRequest request = HttpWebRequest.CreateHttp(baseUri.ToString() + "security/web/get?message=text");
		request.Method = "GET";
		request.ContentType = "application/json; charset=UTF-8";
		request.ClientCertificates.Add(new X509Certificate2("../../Certificates/yourdomain.server.pfx", "qwerty"));
		using (HttpWebResponse response = (HttpWebResponse)request.GetResponse())
			using (StreamReader reader = new StreamReader(response.GetResponseStream(), Encoding.UTF8))
				string html = reader.ReadToEnd();
				Console.WriteLine(html);
	catch (WebException ex)
		throw new Exception(ex.Message);
	Console.ReadLine ();
	host.Close ();
Код: sql
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
Unhandled Exception:
System.InvalidOperationException: Operation is not valid due to the current state of the object.
  at Mono.Net.Security.MobileAuthenticatedStream.ValidateCreateContext (System.Boolean serverMode, System.String targetHost, System.Security.Authentication.SslProtocols enabledProtocols, System.Security.Cryptography.X509Certificates.X509Certificate serverCertificate, System.Security.Cryptography.X509Certificates.X509CertificateCollection clientCertificates, System.Boolean clientCertRequired) [0x0000b] in <5641e4edad4f4464ba58c620a7b8ea48>:0
  at Mono.Net.Security.MobileAuthenticatedStream.AuthenticateAsServer (System.Security.Cryptography.X509Certificates.X509Certificate serverCertificate, System.Boolean clientCertificateRequired, System.Security.Authentication.SslProtocols enabledSslProtocols, System.Boolean checkCertificateRevocation) [0x00000] in <5641e4edad4f4464ba58c620a7b8ea48>:0
  at Mono.Net.Security.Private.MonoSslStreamWrapper.AuthenticateAsServer (System.Security.Cryptography.X509Certificates.X509Certificate serverCertificate, System.Boolean clientCertificateRequired, System.Security.Authentication.SslProtocols enabledSslProtocols, System.Boolean checkCertificateRevocation) [0x00006] in <5641e4edad4f4464ba58c620a7b8ea48>:0
  at System.Net.HttpConnection.Init () [0x0001d] in <5641e4edad4f4464ba58c620a7b8ea48>:0
  at System.Net.HttpConnection.Close (System.Boolean force_close) [0x000e3] in <5641e4edad4f4464ba58c620a7b8ea48>:0
  at System.Net.HttpListenerResponse.Close (System.Boolean force) [0x00012] in <5641e4edad4f4464ba58c620a7b8ea48>:0
  at System.Net.HttpListenerResponse.Close () [0x0000c] in <5641e4edad4f4464ba58c620a7b8ea48>:0
  at System.ServiceModel.Channels.Http.HttpStandaloneResponseInfo.Close () [0x00000] in <abc049434133440d8dd6b5b31f2f4992>:0
  at System.ServiceModel.Channels.Http.HttpContextInfo.Close () [0x00006] in <abc049434133440d8dd6b5b31f2f4992>:0
  at System.ServiceModel.Channels.Http.HttpRequestContext.InternalClose (System.TimeSpan timeout) [0x00006] in <abc049434133440d8dd6b5b31f2f4992>:0
  at System.ServiceModel.Channels.Http.HttpRequestContext.Close (System.TimeSpan timeout) [0x00000] in <abc049434133440d8dd6b5b31f2f4992>:0
  at System.ServiceModel.Channels.Http.HttpRequestContext.Close () [0x0000c] in <abc049434133440d8dd6b5b31f2f4992>:0
  at System.ServiceModel.Dispatcher.ListenerLoopManager.ProcessRequest (System.ServiceModel.Channels.IReplyChannel reply, System.ServiceModel.Channels.RequestContext rc) [0x0007f] in <abc049434133440d8dd6b5b31f2f4992>:0
  at System.ServiceModel.Dispatcher.ListenerLoopManager.TryReceiveRequestDone (System.IAsyncResult result) [0x0001a] in <abc049434133440d8dd6b5b31f2f4992>:0
  at (wrapper managed-to-native) System.Runtime.Remoting.Messaging.AsyncResult:Invoke (System.Runtime.Remoting.Messaging.AsyncResult)
  at System.Runtime.Remoting.Messaging.AsyncResult.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0
  at System.Threading.ThreadPoolWorkQueue.Dispatch () [0x00096] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0
  at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.InvalidOperationException: Operation is not valid due to the current state of the object.
