В чем ошибка?
Взял пример с этого сайта по работе в ASP.NET c БД в SQL: <%@ Page Language="C#" %> <%@ Import NameSpace="System.Data" %> <%@ Import NameSpace="System.Data.SQL" %> <HTML> <script language="C#" runat="server"> void Page_Load(Object obj, EventArgs e) { SQLConnection myConnection = new SQLConnection( "server=localhost; uid=sa; pwd=; database=filmsSQL"); SQLDataSetCommand myCommand = new SQLDataSetCommand( "select NameRus, NameEng, Comment from tblFilms order by NameRus ASC", myConnection); DataSet ds = new DataSet(); myCommand.FillDataSet(ds, "tblFilms"); MyDataList.DataSource = ds.Tables["tblFilms"].DefaultView; MyDataList.DataBind(); } </script> <body topmargin="0" leftmargin="0" marginwidth="0" marginheight="0"> <ASP:DataList id="MyDataList" RepeatColumns="1" RepeatDirection="Horizontal" runat="server"> <template name="itemtemplate"> <div style="padding:15,15,15,15; font-size:10pt; font-family:Verdana"> <b>Русское название:</b> <%# DataBinder.Eval(Container.DataItem, "NameRus") %> <br> <b>Английское название:</b> <%# DataBinder.Eval(Container.DataItem, "NameEng") %> <br> <b>Примечание:</b> <%# DataBinder.Eval(Container.DataItem, "Comment") %> </div> </template> </ASP:DataList> </body> </HTML> Появляется след. ошибка: Parser Error Description: An error occurred during the parsing of a resource required to service this request. Please review the following specific parse error details and modify your source file appropriately. Parser Error Message: Type 'System.Web.UI.WebControls.DataList' does not have a property named 'template'. Source Error: Line 24: <body topmargin="0" leftmargin="0" marginwidth="0" marginheight="0"> Line 25: <ASP:DataList id="MyDataList" RepeatColumns="1" RepeatDirection="Horizontal" runat="server"> Line 26: <template name="itemtemplate"> Line 27: <div style="padding:15,15,15,15; font-size:10pt; font-family:Verdana"> Line 28: <b>Русское название:</b> Source File: c:\inetpub\wwwroot\films\Default.aspx Line: 26 Подскажите пожалуйста в чем она заключается? Thanks ... |
| 14.01.2003, 17:30:06 |
В чем ошибка?
Parser Error Message: Type 'System.Web.UI.WebControls.DataList' does not have a property named 'template'. у типа 'System.Web.UI.WebControls.DataList' отсутствует свойство 'template' м.б. полечится установкой последнего .Net framework'a ... |
| 15.01.2003, 10:04:04 |
В чем ошибка?
Закачал этот файл на пробный хостинг ASP.NET. Там тоже выдается ошибка. Может быть это ошибка в коде, а не в версии ASP.NET? Може быть переменной template не существует? Как тогда используя C# вывести DataList? HELP!!! ... |
| 16.01.2003, 10:59:58 |
В чем ошибка?
где ты такой пример выдрал? ошибка на ошибке... ... |
| 16.01.2003, 11:42:45 |
В чем ошибка?
пример взят с http://www.sql.ru/docs/AccessingData/ASP/NET/3.shtml В чем мои ошибки? ... |
| 16.01.2003, 15:19:10 |
В чем ошибка?
открыл я этот код в VS.Net, начал разбираться...потом плюнул - матюков наслушался... вот код по DataList'у на ВБ правда, но конвертнуть не трудно: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. ... |
| 16.01.2003, 16:24:53 |
В чем ошибка?
кстати, если есть желание могу кинуть книгу по мылу ASP#.NET Web developer's guide - код оттуда ... |
| 16.01.2003, 16:26:41 |
В чем ошибка?
Если можно, что кинь книжку на atum@nm.ru На VB у меня тоже работает, а я хочу разобраться как это делается на C#. Если знаешь, то объясни несведущему как это делается на C# ... |
| 16.01.2003, 16:53:47 |
start [/forum/topic.php?fid=18&gotonew=1&tid=1396592]: |
25ms |
288ms |
23ms |
100ms |
| others: | 332ms |
| total: | 817ms |
