Troubles with OnMouseOver event
Hello Guys! Can anyone tell me how can i solve trouble with onmouseover event in ASP.Net. I need to creat an ImageButton with onmouseover event, which change ImageURL. Why can not i use some html forms - first, my JavaScript code doesnt work in this ASPX document and i need to send some data from DB, which will be calculated on server side and then sends to this ImageButton. If you know how to solve this problem or know some other alternative solution, please, email me to: perevalov@samsung.ru i'll be very thankful to you! Best regards! Alex ... |
| 24.12.2003, 17:50:57 |
это кажется из этой же истории Код: plaintext 1. только код надо модифицировать соответствующим образом. ... |
| 25.12.2003, 12:12:01 |
hey, May be but i have the another problem. Using VB code on serverside i'm sending the data to Alt in this ImageButton. And in ASP.Net there is no OnMouseOver event,right? so we can use JavaScript on usersside, but Server must calculate this data, and so this event must be on server's side. Using OnClick i can do it, but i need exectly mouse Over. I've heard about some library with two components, which are artificialy have onMouseOver even. But i can not install this library:-)) too stupid i am, i think. If you interested in, i can send this library to you. Thanks for the answer! Best regards, AP ... |
| 25.12.2003, 14:58:59 |
passs, чтобы использовать OnMouseOver нужно onclick поменять на onmouseover - всего делов то. ну и код скрипта тоже. ... |
| 25.12.2003, 16:41:18 |
I think it is not so simple, because there is just NO onmouse over event in ASP.NET components. And this exchange will bring a mistake, i tried. ... |
| 26.12.2003, 10:26:56 |
давайте отложим этот вопрос до пн, что-то у меня сегодня настроение уже не рабочее, хотя имхо проблем там особых нет, впрочем посмотрим :) ... |
| 26.12.2003, 14:53:03 |
Hey, thanks for help! Tried as you said, jest exchange onclick to onmouseover. Doesn't work. Dont show a mistake, but this event doesn't work. I think it is because of protection. Maybe it was done because of: if user roll mouse over some object, data will be sending to server, there calculate and then send back. So it is passive event and may make work of some application slow. But actualy i dont know:-) I've wrote what i needed in PHP+JavaScript, but if you know how to solve this problem i'll be very thankful to you, because in very soon future i'll have to create an ASP.NET application. Best regars, AP ... |
| 29.12.2003, 10:18:58 |
start [/forum/topic.php?fid=18&gotonew=1&tid=1396076]: |
26ms |
53ms |
82ms |
| others: | 335ms |
| total: | 569ms |
