Visual Studio 2005 - installationerror
privet wsem! pri instoljazii VS2005 poluchaju sledujuschii error "Microsoft SQL Server 2005 CTP Setup has encoutered a problem and will end. Informieren Sie Microsoft über dieses Problem." Stalkivalsja kto-nibud s takoi problemoi? Na wsjakii sluchai potokoll - dd_vserror80.txt: "[08/17/05,18:34:04] VS Scenario: [2] *** Blocking Components exist and must be satisified before continuing to install *** [08/17/05,18:34:04] VS Scenario: [2] Microsoft Windows 2003 Server [08/17/05,18:34:04] VS Scenario: [2] Microsoft SQL Server 9 service is either not started or not installed [08/17/05,18:34:05] VS Scenario: [2] Microsoft SQL Server 9 Analysis Services is either not started or not installed. [08/17/05,18:34:05] VS Scenario: [2] Microsoft SQL Server 9 Report Server service is either not started or not installed. [08/17/05,18:34:05] VS Scenario: [2] Sharepoint Web Server Extensions is not compatible with Visual Studio Team Foundation or is not installed [08/17/05,18:34:05] VS Scenario: [2] *** End of Blocking Component List *** [08/17/05,18:34:58] VS Scenario: [2] Failed to pass the Warnings/Blocks checks in CVSScenario::Start() [08/17/05,19:02:43] VS Scenario: [2] *** Blocking Components exist and must be satisified before continuing to install *** [08/17/05,19:02:43] VS Scenario: [2] Microsoft Windows 2003 Server [08/17/05,19:02:43] VS Scenario: [2] Microsoft SQL Server 9 service is either not started or not installed [08/17/05,19:02:44] VS Scenario: [2] Microsoft SQL Server 9 Analysis Services is either not started or not installed. [08/17/05,19:02:44] VS Scenario: [2] Microsoft SQL Server 9 Report Server service is either not started or not installed. [08/17/05,19:02:44] VS Scenario: [2] Sharepoint Web Server Extensions is not compatible with Visual Studio Team Foundation or is not installed [08/17/05,19:02:44] VS Scenario: [2] *** End of Blocking Component List *** [08/17/05,19:03:05] VS Scenario: [2] Failed to pass the Warnings/Blocks checks in CVSScenario::Start() [08/17/05,19:11:00] VS Scenario: [2] *** Blocking Components exist and must be satisified before continuing to install *** [08/17/05,19:11:00] VS Scenario: [2] Windows XP Service Pack 2 Update Information [08/17/05,19:11:00] VS Scenario: [2] *** End of Blocking Component List *** [08/17/05,19:23:58] VS Scenario: [2] Failed to pass the Warnings/Blocks checks in CVSScenario::Start() [08/19/05,14:14:32] Microsoft SQL Server 2005 Express Edition April CTP: [2] Error code 1603 for this component means "Schwerwiegender Fehler bei der Installation. " [08/19/05,14:14:33] Microsoft SQL Server 2005 Express Edition April CTP: [2] Setup Failed on component Microsoft SQL Server 2005 Express Edition April CTP [08/19/05,14:17:06] VS70pgui: [2] DepCheck indicates Microsoft SQL Server 2005 Express Edition April CTP is not installed. ***EndOfSession***[09/08/05,22:17:14] Microsoft SQL Server 2005 Express Edition April CTP: [2] Error code 1603 for this component means "Schwerwiegender Fehler bei der Installation. " [09/08/05,22:17:14] Microsoft SQL Server 2005 Express Edition April CTP: [2] Setup Failed on component Microsoft SQL Server 2005 Express Edition April CTP [09/08/05,22:17:21] VS70pgui: [2] DepCheck indicates Microsoft SQL Server 2005 Express Edition April CTP is not installed. ***EndOfSession***[09/09/05,22:04:25] Microsoft SQL Server 2005 Express Edition April CTP: [2] Error code 1603 for this component means "Schwerwiegender Fehler bei der Installation. " [09/09/05,22:04:26] Microsoft SQL Server 2005 Express Edition April CTP: [2] Setup Failed on component Microsoft SQL Server 2005 Express Edition April CTP [09/09/05,22:04:49] VS70pgui: [2] DepCheck indicates Microsoft SQL Server 2005 Express Edition April CTP is not installed. [09/09/05,22:21:51] Microsoft SQL Server 2005 Express Edition April CTP: [2] Error code 1603 for this component means "Schwerwiegender Fehler bei der Installation. " [09/09/05,22:21:52] Microsoft SQL Server 2005 Express Edition April CTP: [2] Setup Failed on component Microsoft SQL Server 2005 Express Edition April CTP [09/09/05,22:22:01] VS70pgui: [2] DepCheck indicates Microsoft SQL Server 2005 Express Edition April CTP is not installed. [09/12/05,00:09:53] Microsoft SQL Server 2005 Express Edition April CTP: [2] Error code 1603 for this component means "Schwerwiegender Fehler bei der Installation. " [09/12/05,00:09:54] Microsoft SQL Server 2005 Express Edition April CTP: [2] Setup Failed on component Microsoft SQL Server 2005 Express Edition April CTP [09/12/05,00:10:02] VS70pgui: [2] DepCheck indicates Microsoft SQL Server 2005 Express Edition April CTP is not installed. ***EndOfSession***[09/15/05,22:14:56] Microsoft SQL Server 2005 Express Edition April CTP: [2] Error code 1603 for this component means "Schwerwiegender Fehler bei der Installation. " [09/15/05,22:14:58] Microsoft SQL Server 2005 Express Edition April CTP: [2] Setup Failed on component Microsoft SQL Server 2005 Express Edition April CTP ***EndOfSession***" Blagodarju. Nachinajuschii. ... |
| 16.09.2005, 00:43 |
start [/forum/topic.php?fid=18&gotonew=1&tid=1393605]: |
60ms |
| others: | 253ms |
| total: | 370ms |
