JS: так как таки из window.clipboardData выдернуть бинарные данные?
JS: так как таки из window.clipboardData выдернуть бинарные данные? ... |
| 21.01.2006, 15:06 |
getData(формат) Posted via ActualForum NNTP Server 1.3 ... |
| 23.01.2006, 14:08 |
Вот-вот! Догадывался об этом, а какие бывают эти "формат" никак не найду. Очень прошу хоть пару конкретных образцов. 1000 благодарностей.. ... |
| 23.01.2006, 18:58 |
Придется цитировать MSDN getData Method ________________________________________________________________________ Retrieves the data in the specified format from the clipboard through the dataTransfer or clipboardData objects. Syntax sRetrieveData = object.getData(sDataFormat) Parameters sDataFormatRequired. String that specifies one of the following data format values: TextRetrieves data formatted as text. URLRetrieves data formatted as a URL. Return Value String. Returns the data in the format retrieved from clipboard through the dataTransfer or clipboardData object. Depending on the information contained in setData, this variable can retrieve a path to an image, text, or an anchor URL. setData Method ________________________________________________ Assigns data in a specified format to the dataTransfer or clipboardData object. Syntax bSuccess = object.setData(sDataFormat, sData) Parameters sDataFormatRequired. String that specifies the format of the data to be transferred, using one of the following values: TextTransfers data formatted as text. URLTransfers data formatted as a URL. sDataRequired. String that specifies the data supplied by the source object. This information can be descriptive text, a source path to an image, or a URL for an anchor. When you pass "URL" as the sDataFormat parameter, you must use the sData parameter to provide the location of the object being transferred. Return Value Boolean. Returns one of the following possible values: trueThe data was successfully added. falseThe data was not added. Remarks The value of the sDataFormat parameter is not case-sensitive. Posted via ActualForum NNTP Server 1.3 ... |
| 24.01.2006, 15:38 |
спасибо-извините за беспокойство-и все такое-а толку-то-мало - выходит что только стринги получать через клипбоард на клинте можно. а мне бы произвольные х16 - я бы их уж попарсил бы... ... |
| 24.01.2006, 17:15 |
start [/forum/topic.php?fid=18&gotonew=1&tid=1393103]: |
85ms |
61ms |
| others: | 240ms |
| total: | 439ms |
