Не получается запустить DotNet приложение с момощью ASPX
экзешник состоит из одного файла myapp.exe в этом апп пытаюсь открыть соккет запускаю при нажатии на кнопку на aspx страничке через Process.Start(Server.MapPath("myapp.exe"); и получаю вот такой exception System.Configuration.ConfigurationErrorsException: Configuration system failed to initialize ---> System.Configuration.ConfigurationErrorsException: An error occurred loading a configuration file: Access is denied. ---> System.Security.SecurityException: Access is denied. at System.Security.Principal.WindowsIdentity.SafeImpersonate(SafeTokenHandle userToken, WindowsIdentity wi, StackCrawlMark& stackMark) at System.Security.Principal.WindowsIdentity.Impersonate(IntPtr userToken) at System.Configuration.ClientConfigurationHost.Impersonate() at System.Configuration.BaseConfigurationRecord.Impersonate() at System.Configuration.BaseConfigurationRecord.InitConfigFromFile() The Zone of the assembly that failed was: MyComputer --- End of inner exception stack trace --- at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal) at System.Configuration.BaseConfigurationRecord.ThrowIfParseErrors(ConfigurationSchemaErrors schemaErrors) at System.Configuration.BaseConfigurationRecord.ThrowIfInitErrors() at System.Configuration.ClientConfigurationSystem.EnsureInit(String configKey) --- End of inner exception stack trace --- at System.Configuration.ClientConfigurationSystem.EnsureInit(String configKey) at System.Configuration.ClientConfigurationSystem.System.Configuration.Internal.IInternalConfigSystem.GetSection(String sectionName) at System.Configuration.ConfigurationManager.GetSection(String sectionName) at System.Configuration.PrivilegedConfigurationManager.GetSection(String sectionName) at System.Diagnostics.DiagnosticsConfiguration.GetConfigSection() at System.Diagnostics.DiagnosticsConfiguration.Initialize() at System.Diagnostics.DiagnosticsConfiguration.get_Sources() at System.Diagnostics.TraceSource.Initialize() at System.Net.Logging.InitializeLogging() at System.Net.Sockets.TcpListener..ctor(IPAddress localaddr, Int32 port) at Main()... но у меня нету никакого конфига и не нужен он мне да и еще exception вылетает именно в конструкторе SocketListener программа сама программа стартует нормально... что я сделал не так? ... |
| 26.06.2006, 18:56 |
Что было если бы можно было запускать апликашки через asp.net. УЖАС/**********Comments***************************/ We trust you have received the usual lecture from the local System Administrator. It usually boils down to these three things: #1) Respect the privacy of others. #2) Think before you type. #3) With great power comes great responsibility. ... |
| 26.06.2006, 23:27 |
>>Что было если бы можно было запускать апликашки через asp.net. УЖАС И не говори! А если бы программисты с такими способностями работали везде?... Даже слов нет... - Compiling: for(;P("\n"),R-;P("|"))for(e=C;e-;P("_"+(*u++/8)%2))P("|"+(*u/4)%2); Compiling: Success. ... |
| 27.06.2006, 00:07 |
Здравствуйте, conderol, Вы писали: C>Что было если бы можно было запускать апликашки через asp.net. УЖАС C> данное сообщение получено с www.gotdotnet.ru C>ссылка на оригинальное сообщение :???: так и можно ведь запускать просто не все действия позволены что естественно я думал можно как то обойти :shuffle: ... |
| 27.06.2006, 10:44 |
Кхм. Судя по stack trace, ошибка возникает в момент инициализации класса System.Diagnostics.TraceSource, что говорит о том, что у вас возможно включена трассировка, но как-то криво настроена. ... |
| 27.06.2006, 22:45 |
start [/forum/topic.php?fid=18&gotonew=1&tid=1392235]: |
153ms |
61ms |
| others: | 231ms |
| total: | 503ms |
