Проблемы с Object Data Source
Делаю привязку GridView и ObjectDataSource в дизайнере. При UPDATE получаю следующую ошибку: Item has already been added. Key in dictionary: 'Name' Key being added: 'Name' GridView _mainGridView; ObjectDataSource _modelTypesDataSource; protected override void CreateChildControls() { base.CreateChildControls(); // Object Data Source _modelTypesDataSource = new ObjectDataSource(); _modelTypesDataSource.ID = "ModelTypesDataSource"; _modelTypesDataSource.OldValuesParameterFormatString = "{0}"; _modelTypesDataSource.ConflictDetection = ConflictOptions.CompareAllValues; _modelTypesDataSource.TypeName = "GarageBusinessLogicLayer.ModelTypes"; _modelTypesDataSource.SelectMethod = "GetAllModelTypes"; _modelTypesDataSource.InsertMethod = "CreateModelType"; _modelTypesDataSource.DeleteMethod = "DeleteModelType"; _modelTypesDataSource.UpdateMethod = "UpdateMethod"; Parameter updateIdParameter = new Parameter(); updateIdParameter.Type = TypeCode.Int32; updateIdParameter.Name = "ID"; updateIdParameter.Direction = System.Data.ParameterDirection.Input; _modelTypesDataSource.UpdateParameters.Add(updateIdParameter); Parameter updateNameParameter = new Parameter(); updateNameParameter.Type = TypeCode.String; updateNameParameter.Name = "Name"; updateNameParameter.Direction = System.Data.ParameterDirection.Input; _modelTypesDataSource.UpdateParameters.Add(updateNameParameter); Controls.Add(_modelTypesDataSource); _modelTypesDataSource.DataBind(); _mainGridView = new GridView(); _mainGridView.AutoGenerateColumns = true; _mainGridView.AutoGenerateDeleteButton = true; _mainGridView.AutoGenerateEditButton = true; _mainGridView.AutoGenerateSelectButton = true; _mainGridView.DataSourceID = _modelTypesDataSource.ID; _mainGridView.DataKeyNames = new string[] { "ID" }; Controls.Add(_mainGridView); _mainGridView.DataBind(); } ... |
| 20.07.2006, 10:11 |
start [/forum/topic.php?fid=18&gotonew=1&tid=1391502]: |
166ms |
38ms |
| others: | 245ms |
| total: | 494ms |
