Динамическое создание картинки вэб-сайта
Помогите в таком вопросе — нужно динамически создавать картинку определённой страницы вэб-сайта по URL и сохранять результат в jpeg. ... |
| 03.07.2006, 13:55 |
<%@ Page Language="VB" %> <%@ import Namespace="System.Drawing" %> <%@ import Namespace="System.Drawing.Imaging" %> <%@ import Namespace="System.Drawing.Drawing2D" %> <script runat="server"> Private Sub Page_Load(sender As Object, e As EventArgs) ' Set the page's content type to JPEG files ' and clear all response headers. Response.ContentType = "image/jpeg" Response.Clear() ' Buffer response so that page is sent ' after processing is complete. Response.BufferOutput = True ' Create a font style. Dim rectangleFont As New Font( _ "Arial", 10, FontStyle.Bold) ' Create integer variables. Dim height As Integer = 100 Dim width As Integer = 200 ' Create a random number generator and create ' variable values based on it. Dim r As New Random() Dim x As Integer = r.Next(75) Dim a As Integer = r.Next(155) Dim x1 As Integer = r.Next(100) ' Create a bitmap and use it to create a ' Graphics object. Dim bmp As New Bitmap( _ width, height, PixelFormat.Format24bppRgb) Dim g As Graphics = Graphics.FromImage(bmp) g.SmoothingMode = SmoothingMode.AntiAlias g.Clear(Color.LightGray) ' Use the Graphics object to draw three rectangles. g.DrawRectangle(Pens.White, 1, 1, width - 3, height - 3) g.DrawRectangle(Pens.Aquamarine, 2, 2, width - 3, height - 3) g.DrawRectangle(Pens.Black, 0, 0, width, height) ' Use the Graphics object to write a string ' on the rectangles. g.DrawString("ASP.NET Samples", rectangleFont, SystemBrushes.WindowText, New PointF(10, 40)) ' Apply color to two of the rectangles. g.FillRectangle( _ New SolidBrush( _ Color.FromArgb(a, 255, 128, 255)), _ x, 20, 100, 50) g.FillRectangle( _ New LinearGradientBrush( _ New Point(x, 10), _ New Point(x1 + 75, 50 + 30), _ Color.FromArgb(128, 0, 0, 128), _ Color.FromArgb(255, 255, 255, 240)), _ x1, 50, 75, 30) ' Save the bitmap to the response stream and ' convert it to JPEG format. bmp.Save(Response.OutputStream, ImageFormat.Jpeg) ' Release memory used by the Graphics object ' and the bitmap. g.Dispose() bmp.Dispose() ' Send the output to the client. Response.Flush() End Sub 'Page_Load </script> <html> <head> </head> <body> <form runat="server"> </form> </body> </html>---------------------------------------- Knowledge is power! My site ... |
| 03.07.2006, 14:15 |
Записать не проблема — проблема получить картинку самой страницы — её скриншот. ... |
| 03.07.2006, 14:53 |
А не подскажете еод такой же , тока ни си шарпе ? Сорри за лень ))) ... |
| 20.07.2006, 14:27 |
Можно и на Шарпее <%@ Page Language="C#" %> <%@ import Namespace="System.Drawing" %> <%@ import Namespace="System.Drawing.Imaging" %> <%@ import Namespace="System.Drawing.Drawing2D" %> <script runat="server"> private void Page_Load(object sender, EventArgs e) { // Set the page's content type to JPEG files // and clear all response headers. Response.ContentType = "image/jpeg"; Response.Clear(); // Buffer response so that page is sent // after processing is complete. Response.BufferOutput = true; // Create a font style. Font rectangleFont = new Font( "Arial", 10, FontStyle.Bold); // Create integer variables. int height = 100; int width = 200; // Create a random number generator and create // variable values based on it. Random r = new Random(); int x = r.Next(75); int a = r.Next(155); int x1 = r.Next(100); // Create a bitmap and use it to create a // Graphics object. Bitmap bmp = new Bitmap( width, height, PixelFormat.Format24bppRgb); Graphics g = Graphics.FromImage(bmp); g.SmoothingMode = SmoothingMode.AntiAlias; g.Clear(Color.LightGray); // Use the Graphics object to draw three rectangles. g.DrawRectangle(Pens.White, 1, 1, width-3, height-3); g.DrawRectangle(Pens.Aquamarine, 2, 2, width-3, height-3); g.DrawRectangle(Pens.Black, 0, 0, width, height); // Use the Graphics object to write a string // on the rectangles. g.DrawString( "ASP.NET Samples", rectangleFont, SystemBrushes.WindowText, new PointF(10, 40)); // Apply color to two of the rectangles. g.FillRectangle( new SolidBrush( Color.FromArgb(a, 255, 128, 255)), x, 20, 100, 50); g.FillRectangle( new LinearGradientBrush( new Point(x, 10), new Point(x1 + 75, 50 + 30), Color.FromArgb(128, 0, 0, 128), Color.FromArgb(255, 255, 255, 240)), x1, 50, 75, 30); // Save the bitmap to the response stream and // convert it to JPEG format. bmp.Save(Response.OutputStream, ImageFormat.Jpeg); // Release memory used by the Graphics object // and the bitmap. g.Dispose(); bmp.Dispose(); // Send the output to the client. Response.Flush(); } </script> <html> <head> </head> <body> <form runat="server"> </form> </body> </html> Пример то из МСДН---------------------------------------- Knowledge is P...O...w...E...R! My site ... |
| 20.07.2006, 14:46 |
start [/forum/search_topic.php?author=b_ned&author_mode=last_topics&do_search=1]: |
156ms |
41ms |
| others: | 609ms |
| total: | 902ms |
