Вопрос по генерации картинок , хэлп ))
Пользуюсь кодом protected void Page_Load(object sender, EventArgs e) { // Set the page's content type to JPEG files // and clear all response headers. Response.ContentType = "image/jpeg"; Response.Clear(); // Buffer response so that page is sent // after processing is complete. Response.BufferOutput = true; // Create a font style. Font rectangleFont = new Font( "Arial", 10, FontStyle.Bold); // Create integer variables. int height = 100; int width = 200; // Create a random number generator and create // variable values based on it. Random r = new Random(); int x = r.Next(75); int a = r.Next(155); int x1 = r.Next(100); // Create a bitmap and use it to create a // Graphics object. Bitmap bmp = new Bitmap( width, height, PixelFormat.Format24bppRgb); Graphics g = Graphics.FromImage(bmp); g.SmoothingMode = SmoothingMode.AntiAlias; g.Clear(Color.LightGray); // Use the Graphics object to draw three rectangles. g.DrawRectangle(Pens.White, 1, 1, width-3, height-3); g.DrawRectangle(Pens.Aquamarine, 2, 2, width-3, height-3); g.DrawRectangle(Pens.Black, 0, 0, width, height); // Use the Graphics object to write a string // on the rectangles. g.DrawString( "ASP.NET Samples", rectangleFont, SystemBrushes.WindowText, new PointF(10, 40)); // Apply color to two of the rectangles. g.FillRectangle( new SolidBrush( Color.FromArgb(a, 255, 128, 255)), x, 20, 100, 50); g.FillRectangle( new LinearGradientBrush( new Point(x, 10), new Point(x1 + 75, 50 + 30), Color.FromArgb(128, 0, 0, 128), Color.FromArgb(255, 255, 255, 240)), x1, 50, 75, 30); // Save the bitmap to the response stream and // convert it to JPEG format. bmp.Save(Response.OutputStream, ImageFormat.Jpeg); // Release memory used by the Graphics object // and the bitmap. g.Dispose(); bmp.Dispose(); // Send the output to the client. Response.Flush(); }, однако картинку получаю плохого качества, не можете подсказать, что нужно сделать для хорошего качества? ... |
| 20.07.2006, 16:54 |
После Response.Flush(); надо обязательно делать Response.End(); иначе велика верятность того что в поток будут выведены дополнительные мусорные байты, которые, возможно, и портят вам картину(ку). ... |
| 21.07.2006, 11:32 |
start [/forum/topic.php?fid=18&gotonew=1&tid=1391452]: |
137ms |
23ms |
| others: | 224ms |
| total: | 412ms |
