Узнать адресс хоста
Подскажите как узнать адрес хоста на котором крутиться сервис типа http://212.12.12.12:8080/MyService Заранее благодарен. ... |
| 28.07.2006, 13:38 |
Узнать адресс хоста
public class Global { /// <summary> /// Returns application virtual path without ending slash. /// </summary> public static string AppPath { get { string appPath = HttpContext.Current.Request.ApplicationPath; return (appPath == "/") ? string.Empty : appPath; } } /// <summary> /// Returns application host name including scheme and port if need, without /// ending slash. /// </summary> public static string AppServer { get { Uri uri = HttpContext.Current.Request.Url; string scheme = uri.Scheme; string host = uri.Host; string port = (uri.IsDefaultPort) ? string.Empty : ":" + uri.Port; return string.Format("{0}://{1}{2}", scheme, host, port); } } /// <summary> /// Returns full web-path for current request, without ending slash. /// </summary> public static string AppFullPath { get { return (AppServer + AppPath); } } public static string AppPhysPath { get { return HttpContext.Current.Request.PhysicalApplicationPath; } } } - - - the truth is out there ... |
| 28.07.2006, 14:42 |
start [/forum/search_topic.php?author=kotkew&author_mode=last_topics&do_search=1]: |
206ms |
46ms |
| others: | 2672ms |
| total: | 3078ms |
