Вопрос знатокам
Есть API(.dll+.lib+.h) стороннего производителя, динамическая библиотека сетевых функций. Возможно ли ее использовать в веб-сервисе (вызывать функции из .dll файла проекта, например)? Я пытался как в обычном приложении, дает ошибки Server Error in '/tu' Application. -------------------------------------------------------------------------------- Configuration Error Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately. Parser Error Message: File or assembly name tu, or one of its dependencies, was not found. Source Error: Line 196: <add assembly="System.EnterpriseServices, Version=1.0.5000.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a"/> Line 197: <add assembly="System.Web.Mobile, Version=1.0.5000.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a"/> Line 198: <add assembly="*"/> Line 199: </assemblies> Line 200: </compilation> Source File: c:\windows\microsoft.net\framework\v1.1.4322\Config\machine.config Line: 198 Assembly Load Trace: The following information can be helpful to determine why the assembly 'tu' could not be loaded. === Pre-bind state information === LOG: DisplayName = tu (Partial) LOG: Appbase = file:///c:/inetpub/wwwroot/tu LOG: Initial PrivatePath = bin Calling assembly : (Unknown). === LOG: Policy not being applied to reference at this time (private, custom, partial, or location-based assembly bind). LOG: Post-policy reference: tu LOG: Attempting download of new URL file:///C:/WINDOWS/Microsoft.NET/Framework/v1.1.4322/Temporary ASP.NET Files/tu/2d49e761/ad5bdfc7/tu.DLL. LOG: Attempting download of new URL file:///C:/WINDOWS/Microsoft.NET/Framework/v1.1.4322/Temporary ASP.NET Files/tu/2d49e761/ad5bdfc7/tu/tu.DLL. LOG: Attempting download of new URL file:///c:/inetpub/wwwroot/tu/bin/tu.DLL. LOG: Policy not being applied to reference at this time (private, custom, partial, or location-based assembly bind). LOG: Post-policy reference: tu, Version=1.0.2418.27800, Culture=neutral, PublicKeyToken=null Пытался загружать библиотеку посредством LoadLibrary(), тоже такие же ошибки. Может кто мне может подсказать возможно вообще то , что я пытаюсь сделать. Если возможно, то подсоветуйте. Буду благодарен.Berentan ... |
| 15.08.2006, 18:02 |
start [/forum/topic.php?fid=18&gotonew=1&tid=1390582]: |
162ms |
45ms |
| others: | 246ms |
| total: | 513ms |
