Server Error in '/' Application ????????????
Добрый день. Сделал я проэкт, и захотел его выложить в Интернет. Увидел ужасную штуку: An error has occurred while establishing a connection to the server. When connecting to SQL Server 2005, this failure may be caused by the fact that under the default settings SQL Server does not allow remote connections. (provider: SQL Network Interfaces, error: 26 - Error Locating Server/Instance Specified) Что это может значить????? ... |
| 26.08.2006, 16:49 |
KonstantinMihaДобрый день. Сделал я проэкт, и захотел его выложить в Интернет. Увидел ужасную штуку: An error has occurred while establishing a connection to the server. When connecting to SQL Server 2005, this failure may be caused by the fact that under the default settings SQL Server does not allow remote connections. (provider: SQL Network Interfaces, error: 26 - Error Locating Server/Instance Specified) Что это может значить????? Надо взглянуть на web.config !!! ... |
| 26.08.2006, 17:23 |
<?xml version="1.0"?> <!-- Note: As an alternative to hand editing this file you can use the web admin tool to configure settings for your application. Use the Website->Asp.Net Configuration option in Visual Studio. A full list of settings and comments can be found in machine.config.comments usually located in \Windows\Microsoft.Net\Framework\v2.x\Config --> <configuration> <appSettings> <add key="ConnectionString" value="Data Source=tcp:server_name;Initial Catalog=Database;User ID=name;Password=pass" /> </appSettings> <connectionStrings> <add name="ConnectionString" connectionString="Data Source=tcp:server_name;Initial Catalog=Database;User ID=name;Password=pass" /> </connectionStrings> <system.web> <!-- Set compilation debug="true" to insert debugging symbols into the compiled page. Because this affects performance, set this value to true only during development. --> <compilation debug="false" /> <!-- The <authentication> section enables configuration of the security authentication mode used by ASP.NET to identify an incoming user. --> <authentication mode="Windows" /> <!-- The <customErrors> section enables configuration of what to do if/when an unhandled error occurs during the execution of a request. Specifically, it enables developers to configure html error pages to be displayed in place of a error stack trace. <customErrors mode="RemoteOnly" defaultRedirect="GenericErrorPage.htm"> <error statusCode="403" redirect="NoAccess.htm" /> <error statusCode="404" redirect="FileNotFound.htm" /> </customErrors> --> </system.web> </configuration> ... |
| 26.08.2006, 18:37 |
Вроде нормально ! А в настройках SQL сервера какая авторизация стоит ??? Надо чтоб смешаная была Windows and SQL ! ... |
| 26.08.2006, 18:47 |
Суля по вот этой строке: <add name="ConnectionString" connectionString="Data Source=tcp:server_name;Initial Catalog=Database;User ID=name;Password=pass" /> у вас создается ConnectionString...но вот параметры очень уж смахивают на какие-то, данные для примера...я очень сомневаюсь, что сервер у вас называется tcp:server_name, имя пользователя name, пароль pass, а база данных Database. Я думаю вам стоит отредактировать эту строку в соотвествии с вашими данными относительно SQL Server ... |
| 26.08.2006, 22:37 |
Это я просто реальные имена заменил такими словами, не буду же я в инет выкладывать полностью данные своего SQL сервака ;) ... |
| 27.08.2006, 12:37 |
To OreL: Авторизация по идее стоит смешанная, я ей не могу на сайте хостинга управлять. И другие сайты там нормально работали. На мой вопрос в службу поддержки мне ответели, что ваше приложение пытается законектиться к SQL EXPRESS и на этом все. А как перебить этот конекшион не написали. Прикольно еше и то, что когда я загружаю другое приложение, оно работает и со старым конфигом. Вот адрес моего горе сайта www.quadro-ua.com Надеюсь на помошь. ... |
| 27.08.2006, 12:47 |
Можете расшифровать стоку tcp:server_name. В ней проблема (Хотя расшифровка не поможет, необходимо ее сравнить с той которую предлагает провайдер). Либо вы порт забыли указать либо если вы пытаетесь подключиться в SQL EXPRESS вы используете строку подключения с именем LocalSqlServer---------------------------------------- Knowledge is P...O...w...E...R! My site ... |
| 27.08.2006, 14:07 |
Строка 100% рабочая. Поигрался еше с кодом, после удаления объекта WebPartManager все начинает работать. Что бы это могло значить? ... |
| 27.08.2006, 20:05 |
KonstantinMihaСтрока 100% рабочая. Поигрался еше с кодом, после удаления объекта WebPartManager все начинает работать. Что бы это могло значить? Если стоят SQL EXPRESS и Полный SQL вместе, то попробуй отключить EXPRESS в SQL Server Configuration Manager ! Должно получиться. ... |
| 28.08.2006, 12:34 |
start [/forum/topic.php?fid=18&gotonew=1&tid=1390147]: |
158ms |
49ms |
| others: | 200ms |
| total: | 455ms |
