Редактирование данных в FormView
Доброго времени суток! Подскажите пожалуйста, куда копать. При попытке редактировать данные на страничке (код ниже) выдается сообщение: В операции должен использоваться обновляемый запрос. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.Data.OleDb.OleDbException: В операции должен использоваться обновляемый запрос. Source Error: An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. Собственно код. <%@ Page Language="C#" MasterPageFile="~/Src/AdminMasterPage.master" AutoEventWireup="true" CodeFile="Forms_News.aspx.cs" Inherits="Src_Forms_News" Title="Untitled Page" StylesheetTheme="Default" Theme="Default" %> <asp:Content ID="Content1" ContentPlaceHolderID="AdmContentPlaceHolder" Runat="Server"> <asp:AccessDataSource ID="adsNews" runat="server" ConflictDetection="CompareAllValues" DataFile="~/App_Data/rootkits.mdb" DeleteCommand="DELETE FROM [LNews] WHERE [IDNews] = ? AND [Author] = ? AND [DateTime] = ? AND [Title] = ? AND [Content] = ? AND [Image] = ? AND [PathImage] = ? AND [LastEdit] = ? AND [TSR] = ?" InsertCommand="INSERT INTO [LNews] ([IDNews], [Author], [DateTime], [Title], [Content], [Image], [PathImage], [LastEdit], [TSR]) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?)" OldValuesParameterFormatString="original_{0}" SelectCommand="SELECT [IDNews], [Author], [DateTime], [Title], [Content], [Image], [PathImage], [LastEdit], [TSR] FROM [LNews] WHERE ([IDNews] = ?)" UpdateCommand="UPDATE [LNews] SET [Author] = ?, [DateTime] = ?, [Title] = ?, [Content] = ?, [Image] = ?, [PathImage] = ?, [LastEdit] = ?, [TSR] = ? WHERE [IDNews] = ? AND [Author] = ? AND [DateTime] = ? AND [Title] = ? AND [Content] = ? AND [Image] = ? AND [PathImage] = ? AND [LastEdit] = ? AND [TSR] = ?"> <DeleteParameters> <asp:Parameter Name="original_IDNews" Type="Int32" /> <asp:Parameter Name="original_Author" Type="Int32" /> <asp:Parameter Name="original_DateTime" Type="DateTime" /> <asp:Parameter Name="original_Title" Type="String" /> <asp:Parameter Name="original_Content" Type="String" /> <asp:Parameter Name="original_Image" Type="String" /> <asp:Parameter Name="original_PathImage" Type="String" /> <asp:Parameter Name="original_LastEdit" Type="DateTime" /> <asp:Parameter Name="original_TSR" Type="Int16" /> </DeleteParameters> <UpdateParameters> <asp:Parameter Name="Author" Type="Int32" /> <asp:Parameter Name="DateTime" Type="DateTime" /> <asp:Parameter Name="Title" Type="String" /> <asp:Parameter Name="Content" Type="String" /> <asp:Parameter Name="Image" Type="String" /> <asp:Parameter Name="PathImage" Type="String" /> <asp:Parameter Name="LastEdit" Type="DateTime" /> <asp:Parameter Name="TSR" Type="Int16" /> <asp:Parameter Name="original_IDNews" Type="Int32" /> <asp:Parameter Name="original_Author" Type="Int32" /> <asp:Parameter Name="original_DateTime" Type="DateTime" /> <asp:Parameter Name="original_Title" Type="String" /> <asp:Parameter Name="original_Content" Type="String" /> <asp:Parameter Name="original_Image" Type="String" /> <asp:Parameter Name="original_PathImage" Type="String" /> <asp:Parameter Name="original_LastEdit" Type="DateTime" /> <asp:Parameter Name="original_TSR" Type="Int16" /> </UpdateParameters> <SelectParameters> <asp:QueryStringParameter Name="IDNews" QueryStringField="IDNews" Type="Int32" /> </SelectParameters> <InsertParameters> <asp:Parameter Name="IDNews" Type="Int32" /> <asp:Parameter Name="Author" Type="Int32" /> <asp:Parameter Name="DateTime" Type="DateTime" /> <asp:Parameter Name="Title" Type="String" /> <asp:Parameter Name="Content" Type="String" /> <asp:Parameter Name="Image" Type="String" /> <asp:Parameter Name="PathImage" Type="String" /> <asp:Parameter Name="LastEdit" Type="DateTime" /> <asp:Parameter Name="TSR" Type="Int16" /> </InsertParameters> </asp:AccessDataSource> <asp:FormView ID="fwNews" runat="server" AllowPaging="True" CellPadding="4" DataKeyNames="IDNews" DataSourceID="adsNews" ForeColor="#333333"> <FooterStyle BackColor="#990000" Font-Bold="True" ForeColor="White" /> <EditItemTemplate> IDNews: <asp:Label ID="IDNewsLabel1" runat="server" Text='<%# Eval("IDNews") %>'></asp:Label><br /> Author: <asp:TextBox ID="AuthorTextBox" runat="server" Text='<%# Bind("Author") %>'> </asp:TextBox><br /> DateTime: <asp:TextBox ID="DateTimeTextBox" runat="server" Text='<%# Bind("DateTime") %>'> </asp:TextBox><br /> Title: <asp:TextBox ID="TitleTextBox" runat="server" Text='<%# Bind("Title") %>'> </asp:TextBox><br /> Content: <asp:TextBox ID="ContentTextBox" runat="server" Text='<%# Bind("Content") %>'> </asp:TextBox><br /> Image: <asp:TextBox ID="ImageTextBox" runat="server" Text='<%# Bind("Image") %>'> </asp:TextBox><br /> PathImage: <asp:TextBox ID="PathImageTextBox" runat="server" Text='<%# Bind("PathImage") %>'> </asp:TextBox><br /> LastEdit: <asp:TextBox ID="LastEditTextBox" runat="server" Text='<%# Bind("LastEdit") %>'> </asp:TextBox><br /> TSR: <asp:TextBox ID="TSRTextBox" runat="server" Text='<%# Bind("TSR") %>'> </asp:TextBox><br /> <asp:LinkButton ID="UpdateButton" runat="server" CausesValidation="True" CommandName="Update" Text="Update"> </asp:LinkButton> <asp:LinkButton ID="UpdateCancelButton" runat="server" CausesValidation="False" CommandName="Cancel" Text="Cancel"> </asp:LinkButton> </EditItemTemplate> <RowStyle BackColor="#FFFBD6" ForeColor="#333333" /> <PagerStyle BackColor="#FFCC66" ForeColor="#333333" HorizontalAlign="Center" /> <InsertItemTemplate> Author: <asp:TextBox ID="AuthorTextBox" runat="server" Text='<%# Bind("Author") %>'> </asp:TextBox><br /> DateTime: <asp:TextBox ID="DateTimeTextBox" runat="server" Text='<%# Bind("DateTime") %>'> </asp:TextBox><br /> Title: <asp:TextBox ID="TitleTextBox" runat="server" Text='<%# Bind("Title") %>'> </asp:TextBox><br /> Content: <asp:TextBox ID="ContentTextBox" runat="server" Text='<%# Bind("Content") %>'> </asp:TextBox><br /> Image: <asp:TextBox ID="ImageTextBox" runat="server" Text='<%# Bind("Image") %>'> </asp:TextBox><br /> PathImage: <asp:TextBox ID="PathImageTextBox" runat="server" Text='<%# Bind("PathImage") %>'> </asp:TextBox><br /> LastEdit: <asp:TextBox ID="LastEditTextBox" runat="server" Text='<%# Bind("LastEdit") %>'> </asp:TextBox><br /> TSR: <asp:TextBox ID="TSRTextBox" runat="server" Text='<%# Bind("TSR") %>'> </asp:TextBox><br /> <asp:LinkButton ID="InsertButton" runat="server" CausesValidation="True" CommandName="Insert" Text="Insert"> </asp:LinkButton> <asp:LinkButton ID="InsertCancelButton" runat="server" CausesValidation="False" CommandName="Cancel" Text="Cancel"> </asp:LinkButton> </InsertItemTemplate> <ItemTemplate> IDNews: <asp:Label ID="IDNewsLabel" runat="server" Text='<%# Eval("IDNews") %>'></asp:Label><br /> Author: <asp:Label ID="AuthorLabel" runat="server" Text='<%# Bind("Author") %>'></asp:Label><br /> DateTime: <asp:Label ID="DateTimeLabel" runat="server" Text='<%# Bind("DateTime") %>'></asp:Label><br /> Title: <asp:Label ID="TitleLabel" runat="server" Text='<%# Bind("Title") %>'></asp:Label><br /> Content: <asp:Label ID="ContentLabel" runat="server" Text='<%# Bind("Content") %>'></asp:Label><br /> Image: <asp:Label ID="ImageLabel" runat="server" Text='<%# Bind("Image") %>'></asp:Label><br /> PathImage: <asp:Label ID="PathImageLabel" runat="server" Text='<%# Bind("PathImage") %>'></asp:Label><br /> LastEdit: <asp:Label ID="LastEditLabel" runat="server" Text='<%# Bind("LastEdit") %>'></asp:Label><br /> TSR: <asp:Label ID="TSRLabel" runat="server" Text='<%# Bind("TSR") %>'></asp:Label><br /> <asp:LinkButton ID="EditButton" runat="server" CausesValidation="False" CommandName="Edit" Text="Edit"> </asp:LinkButton> <asp:LinkButton ID="DeleteButton" runat="server" CausesValidation="False" CommandName="Delete" Text="Delete"> </asp:LinkButton> <asp:LinkButton ID="NewButton" runat="server" CausesValidation="False" CommandName="New" Text="New"> </asp:LinkButton> </ItemTemplate> <HeaderStyle BackColor="#990000" Font-Bold="True" ForeColor="White" /> </asp:FormView> </asp:Content> ... |
| 30.08.2006, 18:23 |
Для папки, в которой лежит mdb файл дать права Full Access для юзера, под которым крутится сайт. Многие вещи нам непонятны не оттого, что наши понятия слабы, а оттого, что данные вещи не входят в круг наших понятий. ... |
| 30.08.2006, 20:47 |
Здравствуйте, Dimon aka Manowar, Вы писали: DAM>Для папки, в которой лежит mdb файл дать права Full Access для юзера, под которым крутится сайт. DAM> данное сообщение получено с www.gotdotnet.ru DAM>ссылка на оригинальное сообщение Спасибо! Поставил все как вы посоветовали, но увы, тот же результат. ... |
| 31.08.2006, 11:34 |
start [/forum/topic.php?fid=18&gotonew=1&tid=1390044]: |
178ms |
34ms |
| others: | 204ms |
| total: | 471ms |
