SharpZibLib - вопрос
Добрый день! Подскажите плиз! ZipInputStream s = new ZipInputStream(this.Project.PostedFile.InputStream); ZipEntry theEntry; while ((theEntry = s.GetNextEntry()) != null) { string directoryName = Path.GetDirectoryName(theEntry.Name); string fileName = Path.GetFileName(theEntry.Name); // create directory Directory.CreateDirectory("C:\\"+directoryName); if (fileName != String.Empty) { FileStream streamWriter = File.Create("C:\\"+theEntry.Name); int size = 2048; byte[] data = new byte[2048]; while (true) { size = s.Read(data, 0, 1); Exception Details: System.NullReferenceException: Object reference not set to an instance of an object. на Строке size = s.Read(data, 0, 1); В чем ошибка? ... |
| 29.08.2006, 17:06 |
Добрый день! Подскажите плиз! ZipInputStream s = new ZipInputStream(this.Project.PostedFile.InputStream); ZipEntry theEntry; while ((theEntry = s.GetNextEntry()) != null) { string directoryName = Path.GetDirectoryName(theEntry.Name); string fileName = Path.GetFileName(theEntry.Name); // create directory Directory.CreateDirectory("C:\\"+directoryName); if (fileName != String.Empty) { FileStream streamWriter = File.Create("C:\\"+theEntry.Name); int size = 2048; byte[] data = new byte[2048]; while (true) { size = s.Read(data, 0, 1); Exception Details: System.NullReferenceException: Object reference not set to an instance of an object. на Строке size = s.Read(data, 0, 1); В чем ошибка? Да, ну разумеется s.CanRead стоит true и папка с файлом создается... ... |
| 29.08.2006, 17:09 |
Добрый день! Подскажите плиз! ZipInputStream s = new ZipInputStream(this.Project.PostedFile.InputStream); ZipEntry theEntry; while ((theEntry = s.GetNextEntry()) != null) { string directoryName = Path.GetDirectoryName(theEntry.Name); string fileName = Path.GetFileName(theEntry.Name); // create directory Directory.CreateDirectory("C:\\"+directoryName); if (fileName != String.Empty) { FileStream streamWriter = File.Create("C:\\"+theEntry.Name); int size = 2048; byte[] data = new byte[2048]; while (true) { size = s.Read(data, 0, 1); Exception Details: System.NullReferenceException: Object reference not set to an instance of an object. на Строке size = s.Read(data, 0, 1); В чем ошибка? Да вот еще что поменял на size=s.ReadByte(); И получил: Exception Details: System.ArgumentOutOfRangeException: Specified argument was out of the range of valid values. Parameter name: length ICSharpCode.SharpZipLib.Zip.Compression.Streams.InflaterInputBuffer.ReadClearTextBuffer(Byte[] outBuffer, Int32 offset, Int32 length) ICSharpCode.SharpZipLib.Zip.ZipInputStream.BodyRead(Byte[] b, Int32 off, Int32 len) ICSharpCode.SharpZipLib.Zip.ZipInputStream.InitialRead(Byte[] destination, Int32 offset, Int32 count) ICSharpCode.SharpZipLib.Zip.ZipInputStream.Read(Byte[] destination, Int32 index, Int32 count) ICSharpCode.SharpZipLib.Zip.ZipInputStream.ReadByte() ... |
| 29.08.2006, 17:22 |
Добрый день! Подскажите плиз! ZipInputStream s = new ZipInputStream(this.Project.PostedFile.InputStream); ZipEntry theEntry; while ((theEntry = s.GetNextEntry()) != null) { string directoryName = Path.GetDirectoryName(theEntry.Name); string fileName = Path.GetFileName(theEntry.Name); // create directory Directory.CreateDirectory("C:\\"+directoryName); if (fileName != String.Empty) { FileStream streamWriter = File.Create("C:\\"+theEntry.Name); int size = 2048; byte[] data = new byte[2048]; while (true) { size = s.Read(data, 0, 1); Exception Details: System.NullReferenceException: Object reference not set to an instance of an object. на Строке size = s.Read(data, 0, 1); В чем ошибка? Да, ну разумеется s.CanRead стоит true и папка с файлом создается... Ну что никто не сталкивался с таким? ... |
| 30.08.2006, 19:11 |
Код: plaintext 1. 2. 3. 4. "Helo, word!" - 17 errors 56 warnings ... |
| 30.08.2006, 21:42 |
streamWriter=File.Create(aDestDir+directoryName+fileName); while((size=s.Read(data,0,data.Length))>0) streamWriter.Write(data,0,size); streamWriter.Close(); _________________ "Helo, word!" - 17 errors 56 warnings Да это понятно... У меня тоже самое вроде и написано, но при первом же проходе s.Read(data,0,data.Length) выдает ошибку... ... |
| 31.08.2006, 12:15 |
Brian Setzer но при первом же проходе s.Read(data,0,data.Length) выдает ошибку какую? Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79. 80. 81. 82. 83. 84. 85. 86. 87. 88. 89. 90. _________________ "Helo, word!" - 17 errors 56 warnings ... |
| 01.09.2006, 00:35 |
start [/forum/search_topic.php?author=Strobery&author_mode=last_topics&do_search=1]: |
181ms |
50ms |
| others: | 1204ms |
| total: | 1503ms |
