Супер БАГ!!!
Приветствую всех любителей необычных багов :) Вот вам один такой. Unable to cast object of type ASP.modules_imagepreview to ASP.modules_imagepreview. Прикол в том, что ASP.NET машина не смогла произвести преобразования типа к самому себе ;) Код класса прилагается using System; using System.Data; using System.ComponentModel; using System.Configuration; using System.Collections; using System.Web; using System.Web.Security; using System.Web.UI; using System.Web.UI.WebControls; using System.Web.UI.WebControls.WebParts; using System.Web.UI.HtmlControls; public partial class Modules_ImagePreview : System.Web.UI.UserControl { #region events public event EventHandler Close; #endregion #region Private variables protected string imageUrl; protected bool enabled = true; #endregion #region Properties public string ImageUrl { get { return this.imageUrl; } set { this.imageUrl = value; } } #endregion #region Functions protected override object SaveControlState() { object obj = base.SaveControlState(); return new object[] {obj, imageUrl, enabled}; } protected override void LoadControlState(object savedState) { object[] savedValues = savedState as object[]; if (savedValues != null) { base.LoadControlState(savedValues[0]); if (savedValues[1] != null) imageUrl = (string)savedValues[1]; if (savedValues[2] != null) enabled = (bool)savedValues[2]; } else { base.LoadControlState(null); } } protected override void OnInit(EventArgs e) { base.OnInit(e); if (Page != null) Page.RegisterRequiresControlState(this); } public void Enable(bool enabled) { closeButton.Enabled = enabled; this.enabled = enabled; } #endregion protected void Page_Load(object sender, EventArgs e) { if (!Page.IsPostBack) { int readOnly = Request.QueryString["readOnly"] != null ? 1 : 0; if (readOnly == 1) { closeButton.Enabled = enabled; } if (imageUrl == "") closeButton.Enabled = enabled; else closeButton.Enabled = enabled; } } protected void closeButton_Click(object sender, ImageClickEventArgs e) { if (Close != null) Close(this, EventArgs.Empty); } } мудр не тот, кто знает многое, а тот, кто знает нужное. ... |
| 03.10.2006, 11:49:56 |
Супер БАГ!!!
Было подобное, оказалось что во временном каталоге куда компилится весь сайт было два файла .dll в которых присутствовал тот же самый тип. Вот она и не может преобразовать, сборка то другая. Попробуй почистить Temporary ASP.NET files в каталоге с фреймворком. ... |
| 03.10.2006, 12:19:29 |
start [/forum/topic.php?fid=18&gotonew=1&tid=1388998]: |
187ms |
46ms |
| others: | 233ms |
| total: | 526ms |
