Получение значения колонки sqldatasource
Как в событии onSelected sqldatasource поучить значение колонки date? news.aspx <asp:SqlDataSource ID="newsEditSqlDataSource" runat="server" ConnectionString="<%$ ConnectionStrings:CommonConnectionString %>" SelectCommand="SELECT id, rubric_id, name, content, is_published, date AS [@xdate], foto, sites_to_publication FROM cms_news WHERE (id = @id)" InsertCommand="INSERT INTO cms_news(rubric_id, name, content, date, foto, sites_to_publication) VALUES (@rubric_id, @name, @content, @date, @foto, @sites_to_publication)"> <SelectParameters> <asp:ControlParameter ControlID="newsGridView" Name="id" PropertyName="SelectedValue" Type="Int32" /> <asp:Parameter Direction="Output" Name="xdate" Type="DateTime" /> </SelectParameters> <InsertParameters> <asp:Parameter Name="rubric_id" /> <asp:Parameter Name="name" /> <asp:Parameter Name="content" /> <asp:Parameter Name="is_published" /> <asp:Parameter Name="date" /> <asp:Parameter Name="foto" /> <asp:Parameter Name="sites_to_publication" /> </InsertParameters> </asp:SqlDataSource> news.aspx.vb Protected Sub newsEditSqlDataSource_Selected(ByVal sender As Object, ByVal e As System.Web.UI.WebControls.SqlDataSourceStatusEventArgs) Handles newsEditSqlDataSource.Selected Message.Text = "Превед" + e.Command.Parameters("@xdate").Value.ToString End Sub ... |
| 02.10.2006, 17:44:38 |
start [/forum/topic.php?fid=18&gotonew=1&tid=1388964]: |
989ms |
35ms |
91ms |
| others: | 223ms |
| total: | 1388ms |
