html из XML и XSL
сталкнулся с такой проблемой есть у меня такой иксемел <?xml version="1.0" encoding="utf-8"?> <Order xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns="http://temeeeeri.org/"> <Number>1</Number> <Title>Super Order</Title> <Date>2006-10-16T15:40:35.6369685+03:00</Date> <_DataSET> <xs:schema id="NewDataSet" xmlns="" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata"> <xs:element name="NewDataSet" msdata:IsDataSet="true" msdata:UseCurrentLocale="true"> <xs:complexType> <xs:choice minOccurs="0" maxOccurs="unbounded"> <xs:element name="Details"> <xs:complexType> <xs:sequence> <xs:element name="ID" type="xs:int" minOccurs="0" /> <xs:element name="Name" type="xs:string" minOccurs="0" /> <xs:element name="Type" type="xs:string" minOccurs="0" /> </xs:sequence> </xs:complexType> </xs:element> </xs:choice> </xs:complexType> </xs:element> </xs:schema> <diffgr:diffgram xmlns:msdata="urn:schemas-microsoft-com:xml-msdata" xmlns:diffgr="urn:schemas-microsoft-com:xml-diffgram-v1"> <NewDataSet xmlns=""> <Details diffgr:id="Details1" msdata:rowOrder="0"> <ID>1</ID> <Name>Pizza</Name> <Type>Papironni</Type> </Details> <Details diffgr:id="Details2" msdata:rowOrder="1"> <ID>2</ID> <Name>Pizza</Name> <Type>Papironni</Type> </Details> <Details diffgr:id="Details3" msdata:rowOrder="2"> <ID>3</ID> <Name>Bus</Name> <Type>Ekarus</Type> </Details> <Details diffgr:id="Details4" msdata:rowOrder="3"> <ID>4</ID> <Name>Nuts</Name> <Type>Gigobyte</Type> </Details> </NewDataSet> </diffgr:diffgram> </_DataSET> </Order> и есть такой иксесел <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform"> <xsl:template match="/"> <table border="1"> <tbody> <tr><td>Number: </td><td><xsl:value-of select="Order/Number"/></td></tr> <tr><td>Title: </td><td><xsl:value-of select="Order/Title"/></td></tr> <tr><td>Date: </td><td><xsl:value-of select="Order/Date"/></td></tr> <tr> <td colspan="2" align="right"> <table border="1"> <tr> <td>ID:</td> <td>Name:</td> <td>Type:</td> </tr> <xsl:for-each select="//Details"> <tr> <td><xsl:value-of select="ID"/></td> <td><xsl:value-of select="Name"/></td> <td><xsl:value-of select="Type"/></td> </tr> </xsl:for-each> </table> </td> </tr> </tbody> </table> </xsl:template> </xsl:stylesheet> програмка Stylus Studio 2007 XML говорит что всё правильно и нармально преобразовывает в html а JavaScript var xmlhttp = new ActiveXObject("Microsoft.XMLHTTP"); var objStyle = new ActiveXObject("Msxml2.DOMDocument.3.0"); objStyle.async = false; objStyle.load("XSLTFile.xsl"); objStyle.resolveExternals = false; var SOAPRequest = new ActiveXObject("Msxml2.DOMDocument.3.0"); SOAPRequest.async = false; var SOAPResponse = new ActiveXObject("Msxml2.DOMDocument.3.0"); SOAPResponse.async = false; function getOrder() { xmlhttp.Open("POST", "http://localhost:4879/WebSite1/WebService.asmx/GetOrder", false); xmlhttp.setRequestHeader("Content-Type", "application/x-www-form-urlencoded"); xmlhttp.send(null); SOAPResponse.loadXML(xmlhttp.responseXML.xml); document.all.orders.innerHTML = SOAPResponse.transformNode(objStyle.documentElement); } не достаёт значения из таких нодав <Number>1</Number> <Title>Super Order</Title> <Date>2006-10-16T15:40:35.6369685+03:00</Date> может ктото знает что я делаю неправельно буду благодарен spydermen ... |
| 16.10.2006, 16:56 |
html из XML и XSL
Скорее всего не отображается из-за различных namespace Попробуй в Xsl файле строчку Код: plaintext Код: plaintext Код: plaintext 1. 2. Код: plaintext 1. 2. ... |
| 18.10.2006, 10:32 |
start [/forum/topic.php?fid=18&gotonew=1&tid=1388492]: |
44ms |
40ms |
| others: | 250ms |
| total: | 384ms |
