Как игнорировать ошибку следующего вида?
Пользую модуль FreeTextBox, это визуальный редактор, когда я нажимаю кнопку сохранить, то выдаётся ошибка A potentially dangerous Request.Form value was detected from the client (FreeTextBox1="<P>some <B>Bold</B> ..."). Description: Request Validation has detected a potentially dangerous client input value, and processing of the request has been aborted. This value may indicate an attempt to compromise the security of your application, such as a cross-site scripting attack. You can disable request validation by setting validateRequest=false in the Page directive or in the configuration section. However, it is strongly recommended that your application explicitly check all inputs in this case. Exception Details: System.Web.HttpRequestValidationException: A potentially dangerous Request.Form value was detected from the client (FreeTextBox1="<P>some <B>Bold</B> ..."). Source Error: [No relevant source lines] Source File: c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET Files\editor\e1043043\8f9d7591\App_Web_ogzucxol.0.cs Line: 0 Stack Trace: [HttpRequestValidationException (0x80004005): A potentially dangerous Request.Form value was detected from the client (FreeTextBox1="<P>some <B>Bold</B> ...").] System.Web.HttpRequest.ValidateString(String s, String valueName, String collectionName) +387 System.Web.HttpRequest.ValidateNameValueCollection(NameValueCollection nvc, String collectionName) +158 System.Web.HttpRequest.get_Form() +131 System.Web.HttpRequest.get_HasForm() +79 System.Web.UI.Page.GetCollectionBasedOnMethod(Boolean dontReturnNull) +63 System.Web.UI.Page.DeterminePostBackMode() +134 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +5914 System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +188 System.Web.UI.Page.ProcessRequest() +112 System.Web.UI.Page.ProcessRequestWithNoAssert(HttpContext context) +37 System.Web.UI.Page.ProcessRequest(HttpContext context) +135 ASP.default_aspx.ProcessRequest(HttpContext context) in c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET Files\editor\e1043043\8f9d7591\App_Web_ogzucxol.0.cs:0 System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +401 System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +117 А мне надо, чтобы оно с тэгами всё сохраняло, не подскажете как быть ?) ... |
| 24.10.2006, 21:59 |
start [/forum/topic.php?fid=18&gotonew=1&tid=1388258]: |
44ms |
49ms |
| others: | 271ms |
| total: | 420ms |
