Maximum request length exceeded.
Всем привет!!!!!!! Я в сайт хочу сохронит rar вский файл на сервер.Если размер файла привишаеть 10 мб выходит такой эксепшин C] Maximum request length exceeded. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.Web.HttpException: Maximum request length exceeded. Source Error: An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. Stack Trace: [HttpException (0x80004005): Maximum request length exceeded.] System.Web.HttpRequest.GetEntireRawContent() +3220285 System.Web.HttpRequest.GetMultipartContent() +62 System.Web.HttpRequest.FillInFormCollection() +264 System.Web.HttpRequest.get_Form() +65 System.Web.HttpRequest.get_HasForm() +57 System.Web.UI.Page.GetCollectionBasedOnMethod(Boolean dontReturnNull) +2022785 System.Web.UI.Page.DeterminePostBackMode() +60 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +133 ... |
| 09.11.2006, 15:57 |
Solution FileUp Standard Edition can accept uploads of up to 4 gigabytes. FileUp Enterprise Edition can accept unlimited size uploads. However, when using the product in .NET, it is important to configure the application settings to make sure ASP.NET doesn't block the large uploads before FileUp can process them. The maxRequestLength parameter is set in the httpRuntime section of web.config (or machine.config). maxRequestLength is set in bytes. So, for example, if you want to allow uploads of 100 MB, you would set maxRequestLength to 102400. There are some other settings in httpRuntime which you may want to modify for large uploads. Below is an example httpRuntime element. Please adjust the settings according to the needs of your application. Leonid ... |
| 20.11.2006, 14:45 |
Solution FileUp Standard Edition can accept uploads of up to 4 gigabytes. FileUp Enterprise Edition can accept unlimited size uploads. However, when using the product in .NET, it is important to configure the application settings to make sure ASP.NET doesn't block the large uploads before FileUp can process them. The maxRequestLength parameter is set in the httpRuntime section of web.config (or machine.config). maxRequestLength is set in bytes. So, for example, if you want to allow uploads of 100 MB, you would set maxRequestLength to 102400. There are some other settings in httpRuntime which you may want to modify for large uploads. Below is an example httpRuntime element. Please adjust the settings according to the needs of your application. "lefttag" httpRuntime executionTimeout="1200" maxRequestLength="102400" useFullyQualifiedRedirectUrl="false" minFreeThreads="8" minLocalRequestFreeThreads="4" appRequestQueueLimit="100" "righttag" Leonid ... |
| 20.11.2006, 14:47 |
start [/forum/topic.php?fid=18&gotonew=1&tid=1387417]: |
36ms |
29ms |
| others: | 216ms |
| total: | 320ms |
