Microsoft.Office.Interop.Word + ASP.NET
При использовании ASP.NET + Microsoft.Office.Interop.Word (12) постоянно выскакивает ошибка Error - The message filter indicated that the application is busy. (Exception from HRESULT: 0x8001010A (RPC_E_SERVERCALL_RETRYLATER)) Microsoft.Office.Interop.Word.Application wap; wap = (Microsoft.Office.Interop.Word.Application)Activator.CreateInstance(Type.GetTypeFromProgID("Word.Application")); //Microsoft.Office.Interop.Word.Application; object templateName = new object(); FileStream file; if (!defTemplate) { templateName = "D:\\!VirtualPath\\e-vko.gov.kz - !services\\temp\\temp_" + DateTime.Now.Millisecond.ToString() + "_" + DateTime.Now.Second.ToString() + "_" + DateTime.Now.Hour.ToString() + ".dot"; file = new FileStream(templateName.ToString(), FileMode.Create); file.Write(templateByte, 0, templateByte.Length); file.Close(); } else templateName = "D:\\!VirtualPath\\e-vko.gov.kz - !services\\temp\\Normal__.dot"; object fileName = "D:\\!VirtualPath\\e-vko.gov.kz - !services\\temp\\temp_" + DateTime.Now.Millisecond.ToString() + "_" + DateTime.Now.Second.ToString() + "_" + DateTime.Now.Hour.ToString() + ".doc"; object missing = Type.Missing; Document doc; doc = wap.Documents.Add(ref templateName, ref missing, ref missing, ref missing); foreach (DictionaryEntry tag in tags) { foreach (Bookmark bm in doc.Bookmarks) if (bm.Name == tag.Key.ToString()) bm.Range.Text = tag.Value.ToString(); } object saveFormat = WdSaveFormat.wdFormatDocument97; doc.SaveAs(ref fileName, ref saveFormat, ref missing, ref missing, ref missing, ref missing, ref missing, ref missing, ref missing, ref missing, ref missing, ref missing, ref missing, ref missing, ref missing, ref missing); doc.Close(ref missing, ref missing, ref missing); wap.Quit(ref missing, ref missing, ref missing); file = new FileStream(fileName.ToString(), FileMode.Open); byte[] content = new byte[file.Length]; file.Read(content, 0, (int)file.Length); file.Close(); File.Delete(fileName.ToString()); if (!defTemplate) File.Delete(templateName.ToString()); Response.Clear(); Response.BinaryWrite(content); Response.ContentType = "application/msword"; Response.AppendHeader("content-disposition", "attachment; filename=Blanc.doc"); Ошибка на первом методе объекта document после его создания (коменчу перебор букмарков, он выдает исключение на SaveAs, коменчу и его - на Close). Причем самое интересное, сервер таки прорывает иногда, и все начинает прекрасно работать (вообще эта ошибка начала лезть после месяца примерно стабильной работы - попробовал на другом железе - то же). Нашел вроде как что MS не рекомендует Com объекты Office из под ASP.NET (http://sadeveloper.net/forums/thread/5852.aspx) Может быть кто сталкивался. Или есть альтернативные компаненты (желательно фри) ... |
| 22.12.2007, 09:21:27 |
есть результаты по этой ошибке ? Аналогичная проблема 1 в 1. Стала проявляться после перехода на Windows Server 2008. На 2003 все работало. Очень нужно, уже несколько недель по-маленьку бодаемся !!! Тому, кто поможет - пива :) ... |
| 13.10.2011, 15:54:03 |
Зачем же так грубо Word вызывать. А ошибку вы не поборете, это политика безопасности. ... |
| 13.10.2011, 16:10:48 |
тут есть кое какие действия : http://forums.iis.net/t/1180514.aspx Но я все равно еще нигде не встречала записей о том, что эврика, заработало :) пс. мы делали xsl-template+xml-data transform > document ... |
| 13.10.2011, 16:21:30 |
вообщем, оказалось все проще и сложнее одновременно. Ворд работал в фоновом режиме и при объеме от 500-1000 страниц выкидывал сообщение об ошибке проверки орфографии, типа буфер переполнился. В коде отключил проверку орфографии. ... |
| 13.10.2011, 21:00:32 |
start [/forum/topic.php?fid=18&gotonew=1&tid=1360502]: |
390ms |
39ms |
| others: | 206ms |
| total: | 671ms |
