PowerPoint
Очень нужна помощь в решении следующей проблемы: Необходимо из ASP.NET работать с PowerPoint. Библиотеки PowerPoint и Graph подключены. Использую скаченный из инета пример: Imports Microsoft.Office.Core Imports System.Runtime.InteropServices Imports Microsoft.Office.Interop.PowerPoint Imports Microsoft.Office.Interop.Graph Imports Microsoft.Office.Interop Partial Class Test_PowerPoint Inherits System.Web.UI.Page Public PowerPoint As Microsoft.Office.Interop.PowerPoint.Application Public Graph As Microsoft.Office.Interop.Graph.Application Protected Sub Button1_Click(sender As Object, e As System.EventArgs) Handles Button1.Click Call ShowPresentation() GC.Collect() End Sub Sub ShowPresentation() Dim strTemplate As String = "C:\Program Files\Microsoft Office\Templates\Presentation Designs\Blends.pot" Dim strPic As String = "C:\Windows\Blue Lace 16.bmp" Dim bAssistantOn As Boolean Dim objApp As PowerPoint.Application Dim objPressSet As PowerPoint.Presentations Dim objPres As PowerPoint._Presentation Dim objSlides As PowerPoint.Slides Dim objSlide As PowerPoint._Slide Dim objTextRng As PowerPoint.TextRange Dim objShapes As PowerPoint.Shapes Dim objShape As PowerPoint.Shape Dim objSSWs As PowerPoint.SlideShowWindows Dim objSST As PowerPoint.SlideShowTransition Dim objSSS As PowerPoint.SlideShowSettings Dim objSldRng As PowerPoint.SlideRange Dim objChart As Graph.Chart ' Create a new presentation based on a template. objApp = New PowerPoint.Application() objApp.Visible = MsoTriState.msoTrue objPressSet = objApp.Presentations objPres = objPressSet.Open(strTemplate, MsoTriState.msoFalse, MsoTriState.msoTrue, MsoTriState.msoTrue) objSlides = objPres.Slides ' Build Slide #1: ' Add text to the slide, change the font and insert/position a picture on the first slide. ' ------------------------------------- objSlide = objSlides.Add(1, objApp.PpSlideLayout.ppLayoutTitleOnly) objTextRng = objSlide.Shapes(1).TextFrame.TextRange objTextRng.Text = "My Sample Presentation" objTextRng.Font.Name = "Comic Sans MS" objTextRng.Font.Size = 48 objSlide.Shapes.AddPicture(strPic, MsoTriState.msoFalse, MsoTriState.msoTrue, 150, 150, 500, 350) . . . Но вот на выделенной строке выдается ошибка: "Object variable or With block variable not set." Почему-то в objApp отсутствует PpSlideLayout. Как быть? ... |
| 05.03.2013, 17:49:02 |
start [/forum/topic.php?fid=18&gotonew=1&tid=1358694]: |
27ms |
47ms |
56ms |
| others: | 364ms |
| total: | 566ms |
