unit test
Error Test UnitTestProject The test adapter 'WebHostAdapter' threw an exception while running test 'Test'. The web site could not be configured correctly; getting ASP.NET process information failed. The server may not be running a version of ASP.NET version 2.0 or greater. Requesting 'http://localhost:4273/VSEnterpriseHelper.axd' returned an error: The remote server returned an error: (400) Bad Request. ... как это победить? ... |
| 29.04.2014, 20:33:10 |
unit test
hshfsfsError Test UnitTestProject The test adapter 'WebHostAdapter' threw an exception while running test 'Test'. The web site could not be configured correctly; getting ASP.NET process information failed. The server may not be running a version of ASP.NET version 2.0 or greater. Requesting 'http://localhost:4273/VSEnterpriseHelper.axd' returned an error: The remote server returned an error: (400) Bad Request. ... как это победить? Мож все-таки кто сталкивался? ... |
| 02.05.2014, 14:38:29 |
start [/forum/topic.php?fid=18&gotonew=1&tid=1357353]: |
51ms |
53ms |
| others: | 303ms |
| total: | 476ms |
