Ошибка Incorrect syntax near 'nvarchar'. Incorrect syntax near 'revenue'.
Не могу разобраться из-за чего ошибка.. Помогите автор<asp:SqlDataSource ID="SqlDataSource1" runat="server" ConnectionString="<%$ ConnectionStrings:ExigenProjectConnectionString %>" SelectCommand="SELECT * FROM [Projects] ORDER BY [EndDate] DESC"></asp:SqlDataSource> <asp:GridView ID="GridView1" runat="server" AutoGenerateColumns="False" DataKeyNames="ProjectId" DataSourceID="SqlDataSource1"> <Columns> <asp:CommandField ShowSelectButton="True" /> <asp:BoundField DataField="StartDate" HeaderText="StartDate" SortExpression="StartDate" /> <asp:BoundField DataField="EndDate" HeaderText="EndDate" SortExpression="EndDate" /> <asp:BoundField DataField="Estimated revenue" HeaderText="Estimated revenue" SortExpression="Estimated revenue" /> </Columns> </asp:GridView> <br /> <asp:DetailsView ID="DetailsView1" runat="server" AutoGenerateRows="False" DataKeyNames="ProjectId" DataSourceID="SqlDataSource2" Height="113px" Width="405px"> <Fields> <asp:BoundField DataField="ProjectId" HeaderText="ProjectId" InsertVisible="False" ReadOnly="True" SortExpression="ProjectId" /> <asp:BoundField DataField="StartDate" HeaderText="StartDate" SortExpression="StartDate" /> <asp:BoundField DataField="EndDate" HeaderText="EndDate" SortExpression="EndDate" /> <asp:BoundField DataField="Estimated revenue" HeaderText="Estimated revenue" SortExpression="Estimated revenue" /> <asp:CommandField ShowDeleteButton="True" ShowEditButton="True" ShowInsertButton="True" /> </Fields> </asp:DetailsView> <br /> <asp:SqlDataSource ID="SqlDataSource2" runat="server" ConnectionString="<%$ ConnectionStrings:ExigenProjectConnectionString %>" DeleteCommand="DELETE FROM [Projects] WHERE [ProjectId] = @ProjectId" InsertCommand="INSERT INTO [Projects] ([StartDate], [EndDate], [Estimated revenue]) VALUES (@StartDate, @EndDate, @Estimated_revenue)" SelectCommand="SELECT * FROM [Projects] WHERE ([ProjectId] = @ProjectId)" UpdateCommand="UPDATE [Projects] SET [StartDate] = @StartDate, [EndDate] = @EndDate, [Estimated revenue] = @Estimated_revenue WHERE [ProjectId] = @ProjectId"> <DeleteParameters> <asp:Parameter Name="ProjectId" Type="Int32" /> </DeleteParameters> <InsertParameters> <asp:Parameter DbType="Date" Name="StartDate" /> <asp:Parameter DbType="Date" Name="EndDate" /> <asp:Parameter Name="Estimated_revenue" Type="Decimal" /> </InsertParameters> <SelectParameters> <asp:ControlParameter ControlID="GridView1" Name="ProjectId" PropertyName="SelectedValue" Type="Int32" /> </SelectParameters> <UpdateParameters> <asp:Parameter DbType="Date" Name="StartDate" /> <asp:Parameter DbType="Date" Name="EndDate" /> <asp:Parameter Name="Estimated_revenue" Type="Decimal" /> <asp:Parameter Name="ProjectId" Type="Int32" /> </UpdateParameters> </asp:SqlDataSource> Если есть возможность у кого нибудь можете дать Skype, задам пару простых вопросов и потом пополню Ваш мобильный счет)) ... |
| 16.09.2014, 08:46:18 |
start [/forum/topic.php?fid=18&gotonew=1&tid=1357001]: |
43ms |
52ms |
| others: | 273ms |
| total: | 431ms |
