net6 + tests
продолжаю эпопею перекатывания на нет6 и теперь новое внезапно тесты крашатся. завершается с разной степенью завершенности и даже проходят порой. но что вижу в логах System.Exception: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.. ---> System.Exception: An existing connection was forcibly closed by the remote host. at System.Net.Sockets.NetworkStream.Read(Span`1 buffer) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Span`1 buffer) at System.Net.Sockets.NetworkStream.ReadByte() at System.IO.BinaryReader.Read7BitEncodedInt() at System.IO.BinaryReader.ReadString() at Microsoft.VisualStudio.TestPlatform.CommunicationUtilities.LengthPrefixCommunicationChannel.NotifyDataAvailable() at Microsoft.VisualStudio.TestPlatform.CommunicationUtilities.TcpClientExtensions.MessageLoopAsync(TcpClient client, ICommunicationChannel channel, Action`1 errorHandler, CancellationToken cancellationToken) у всех кто на нет6 такое или я такой везунчик? ... |
| 14.01.2022, 12:40:39 |
net6 + tests
Ну, так вот же ж автор Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.. ---> System.Exception: An existing connection was forcibly closed by the remote host. ... |
| 14.01.2022, 12:41:56 |
net6 + tests
Ролг Хупин Ну, так вот же ж автор Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.. ---> System.Exception: An existing connection was forcibly closed by the remote host. и? как зафиксить? предлагаешь ковырять TestPlatform.CommunicationUtilities.TcpClientExtensions.MessageLoopAsync ? как я могу повлиять на это дело ... |
| 14.01.2022, 13:07:42 |
net6 + tests
https://github.com/microsoft/vstest/issues/2952 не я один оказывается ... |
| 14.01.2022, 13:13:08 |
start [/forum/topic.php?fid=18&gotonew=1&tid=1354454]: |
49ms |
87ms |
| others: | 297ms |
| total: | 529ms |
