Update DataSet
При обновлении, выдает следующую ошибку: "Dynamic SQL Error\nSQL error code = -104\nToken unknown - line 1, char 8\n\"EVENTS\"\n" В чем ошибка??? public void UpdateSomeTable(DataSet dataSet,string table) { this.Connect(); FbDataAdapter adapter = new FbDataAdapter(); adapter.SelectCommand = new FbCommand("Select * From events",this.myConnection); DataSet dataset = new DataSet(); FbCommandBuilder builder = new FbCommandBuilder(adapter); adapter.Fill(dataset,"events"); dataset.Tables[0].Rows[1][1] = "real"; try { adapter.Update(dataset,"events"); dataset.AcceptChanges(); } catch(Exception ee) { Debug.Listeners.Add(new TextWriterTraceListener(Console.Out)); Debug.AutoFlush = true; Debug.Indent(); Debug.WriteLine(ee.ToString()); Debug.Unindent(); } finally { this.Disconnect(); } } ... |
| 22.09.2004, 12:14:20 |
Update DataSet
посмотри как пример апдейта: public DataSet UpdateDataSet(DataSet ds,string CmdText, string TableName) { SqlConnection myConn = new SqlConnection(this.ConnectionString); SqlDataAdapter myDataAdapter = new SqlDataAdapter(); myDataAdapter.SelectCommand = new SqlCommand(CmdText, myConn); SqlCommandBuilder cb = new SqlCommandBuilder(myDataAdapter); try { myConn.Open(); //code to modify data in DataSet here cb.RefreshSchema(); //Without the SqlCommandBuilder this line would fail myDataAdapter.Update(ds, TableName); return ds; } catch( Exception exception ) { System.Diagnostics.Debug.WriteLine(exception.Message); return null; } finally { // Clean up the objects if( myConn != null ) myConn.Dispose(); } } ... |
| 22.09.2004, 12:57:00 |
start [/forum/topic.php?fid=17&gotonew=1&tid=1354017]: |
181ms |
31ms |
| others: | 232ms |
| total: | 492ms |
